![]() | Home > Puma (Tdci) > Defender for a numpty |
My repairers Waxoyled my Ninety (15ltrs) for 250.
No rust or corrosion showing after 7 years. ![]() |
lukev01 Member Since: 24 Mar 2012 Location: Bedfordshire Posts: 412 ![]() ![]() ![]() |
I had my S2A waxoyled for this. I was thinking about Zagato's recommendations for Dinitrol, talcum powdering its bottom carefully, etc. etc. as well. 1970 Series 2A 88"
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
Luke you can't do much better than getting under it with a paint brush and a pot of POR-15, it will be done for life apart from cavity top ups. The Dinitrol kit has everything as you know as well as a can of rust converter to sort any existing spots, it's mucky but not hard to do
![]() Anti-Corrosion protection seems to be from 250 - 800 Main thing is to not take it to someone who cleans and treats in a days it takes 24hrs with hot blower to 5 days drying naturally for the inside of a chassis ![]() Good luck hunting for a nice one, I'm afraid all I see are corroded ones on forecourts ![]() ![]() |
![]() Thanks, Zagato. Next job is to learn which end of a paintbrush to hold. Will also be worth pointing out areas of corrosion to LR dealers when it comes to that time, might be a bargaining point! ![]() |
You need to do the inside of the chassis as well as the outside.
Remove all internal side panels and treat inside and outside of body and door frames. Best done by a professional. ![]() |
Honker Member Since: 26 Jun 2011 Location: St Albans Posts: 353 ![]() ![]() ![]() |
Or the lazy way.....buy car, drive to rust master in Hatfield, leave overnight , pick up next day, park on drive
![]() Stu |
Sounds good to me...especially if I can negotiate a discount for a rusty new car.
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 ![]() ![]() ![]() |
It will be fine if you Zag it
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 ![]() ![]() |
Laurie Not too far from you who did you use looking at getting my 130 done very soon.. Simon 993 Varioram - Guards Red Defender 2.5 300TDI 110 HCP - Keswick Green Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE |
Bob Pilbeam in Hailsham. They've been our maintenance people for 20 years. ![]() |
I know Bob & Richard
![]() Defender 2.5 300TDI 110 HCP - Keswick Green Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE |
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2671 ![]() ![]() ![]() |
Or you could go to one of the plethora of custom builders, and have a new Defender built to your spec, based on a Galvanized chasis from new
![]() Like this http://www.trekoverland.com/vehicle_details.php?vid=2 Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
I got a quote form these guys for a TDi rebuild, galv chassis, everything new or refurbed, came to 28K.......went for the new TDCi for the same money instead, can always drop in a TDi and run it on veg oil when fuel runs out
johnnyturbo2002 Member Since: 21 May 2009 Location: Poniente Granadino Posts: 371 ![]() ![]() ![]() |
What the flip is a numpty????? 2008 Defender 110 60 year Edition (sold unfortunately)
IN the hunt for another Puma for the wifey! 2008 Kia Sorento LX 😁 2.5crdi |
