![]() | Home > For Sale & Wanted > WTD: TD5 110 Looms |
g30rge Member Since: 31 Mar 2012 Location: Durham, North East England Posts: 3 ![]() ![]() |
Have you tried Autosparks
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1751 ![]() |
Contact Equicar 4x4 and ask to speak to Simon
I assume you are building a 110 CSW. If you are fitting central locking you will need the loom which runs in back of seatbox between B posts and also the roof loom. I know coz I am currently on that learning curve. |
db950 Member Since: 01 Feb 2012 Location: Lincoln Posts: 570 ![]() ![]() ![]() |
Thanks for your replies.
Yes currently doing a full restoration on my 1989 110 sw, and all would of been ok until I bought a td5 bulkhead complete with loom so I thought "why not change all the wiring to td5 spec" oh what a decision that was!! Not fitting central locking so that's a bit less. But thanks for the tip on the roof loom, hadn't thought of that. Sourced a chassis loom and fuse box today from a breaker so the new list is; L/H and R/H wing looms Roof loom Will ring equicar tomorrow Last edited by db950 on 11th Apr 2012 10:16pm. Edited 1 time in total |
Just found out that there is a time out on sending a reply.......just before your about to press SUBMIT !!
Have written two replies with more info for you, butI obviously took too long will PM with my number if you wish to call to discuss further. |
Many thanks romadog will call to discuss.
