![]() | Home > Maintenance & Modifications > Fitting Jate rings |
Maverick Member Since: 08 Mar 2008 Location: Inverurie! Posts: 261 ![]() ![]() ![]() |
I'm trying to fit some Jate rings to the back of my 90 300TDi however there is a flat strip of metal that could present a problem. This is what I'm on about
![]() Click image to enlarge ![]() Click image to enlarge Is it just a case of ignore it and it'll be fine, or is there anything else I can do? TIA Maverick Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Rebuilt 1996 black/white Defender 90 300 TDi |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5108 ![]() ![]() ![]() |
I dont see any issues with that - ive had them fitted in similar scenarios (they soon move in use) Mike
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
Won't it bend the bracket under load? One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
I would disagree - it will pull up, yes, but unless your snatching around i doubt it will do much more. Mike
Well I fitted them to tow my series 3 out the way, and they actually split the metal, creating a cut, so to speak, that the jate rings go into. But they worked perfectly!
