![]() | Home > Puma (Tdci) > 2.2 question |
| Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 610
Any chance of a photo, Rob?
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471
You are not talking about the rubber grommet in the right hand side of steering column shroud are you, if so that's just a left over from where the manual choke control used to be on petrol models. Steve.
This is what I was thinking too! |
| spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4812
That is where your ignition key and barrel would be on right hand drive models.Mine has the blanking grommet where your ignition key and barrel is. 1982 88" 2.25 diesel
The steering cowl is the same on LHD and RHD cars though?
Yes. 1982 88" 2.25 diesel
Ignition is on the left on RHD models. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
| Landyrob Member Since: 07 Jul 2011 Location: Switzerland Posts: 93
here a quick snap....
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Defender TD4 90 Hardtop 2.4 Defender TD4 110 Hardtop 2.2 |
| Higgers Member Since: 08 Apr 2009 Location: Cheshire Posts: 672
It's just a gromit to fill a hole. It's pops in and out quite easily - if I'm looking at the right thing.........
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6205
It does make me smile why LR still use these column shrouds with the choke cable cut-out.... Carb V8's havn't been factory fitted since, when, 1996? (ish) and most certainly not since the Td5 came into fruition....
Maybe LR have a warehouse full of these shrouds they're slowly working their way through |
Yep, leftover from the old manual choke days [ISTR having one with a diesel cutoff pull mounted there too but might be just a brain f@rt. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
okay thanks for the info guys....
| cradgebank Member Since: 30 Dec 2008 Location: Nottingham Posts: 308
LR have been using that shroud since 1983 on the first 110's, guess it must be a case of 'Don't fix what aint broke". Richard
Either a 90, 110 or 130. Discovery 5 |
