![]() | Home > Camping, Caravanning and Holidays > Which towing mirrors do you use? |
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
Which towing mirrors do you use (if any)?
Not wanting to create a debate on whether to use towing mirrors or not. Lately Ive decided to use them (previously towed with mirror arms pushed out) and I use Lorrymans idea of adapting the Milenco Grand Aero mirrors to fit onto my wing mirrors, but lately the wind resistance has caused the drivers wing mirror head to fold in as I drive ![]() Interested in hearing what mirrors folk use:D |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
Just extended arms with normal mirrors.
Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Milenco Aero, but clipped to the underside of the arms rather than the mirror heads. Darren
IanW Member Since: 12 Jun 2011 Location: Gloucestershire Posts: 172 ![]() ![]() ![]() |
Milenco Aero again, clipped to the underside of the LR arm, but with a cable tie through the aero fixing (convenient holes) and LR mirror arms in case the fixing fails for some reason. Ian One wife - livid
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982 ![]() ![]() |
Wolf arms and mirrors. Great, just swing them out when I need them. Bigger glass area too.
Merlin |
Clamped to the arm instead of the glass. It means folding the arms out and moving the Defender mirrors but is very stable and no cracked glass
![]() ![]() Click image to enlarge ![]() Click image to enlarge John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
RFT Member Since: 13 Nov 2010 Location: Yorkshire Dales Posts: 691 ![]() ![]() ![]() |
My solution.
http://www.defender2.net/forum/topic10315.html Richard 130 Puma HCPU with an Artica 240LR Demountable Camper |
I'll try fitting them to the mirror arms, perhaps with a tie clip as well as per IanW's suggestion
Wolf mirror arms.
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 370 ![]() ![]() ![]() |
Just ordered some of these genuine Britax arms and mirrors after having a genuine 'wolf' arm fail. I've tried some eBay after-market wolf-like arms and mirrors and the quality was shocking and not fit for purpose. Once the new genuine Britax ones turn up I taking these eBay 'specials' back to the seller personally ![]() Green Goddess - 1998 Defender 110 300tdi |
And have now just realised the Britax ones won't fit because of the raised air intake ![]() Green Goddess - 1998 Defender 110 300tdi |
TR51 Member Since: 17 Apr 2012 Location: Dorset UK Posts: 333 ![]() ![]() ![]() |
I use Pyramid Rock Steady mirrors, but take care not to tighten them up too tight on the glass!!
They are very stable, but helps if the straps are 'crossed' at the back. ![]() |
Following the suggestions on here, Ive now mounted my Grand Aero towing mirrors onto the underside of my mirror arms, and secured with a tie clip incase they work loose. Now the law states this is the view you should achieve...
![]() Yet the best view I can achieve is this... ![]() Click image to enlarge Clearly I cant see the actual sides of my caravan, so I guess I need to get some extended mirror arms now! Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
This may be daft but I take it your mirrors are pushed back to 90 degrees?
And would you be able to see down the sides if the mirrors were attached to the glass (another couple of inches?)
