Home > Td5 > Clutch release bearing noise?
excossack
After replacing the clutch, pressure plate,DMT release bearing the clutch was quiet when I had the foot on the clutch or when bring it up to get the bite.
Now its started making a whir whir noise its only when operating the clutch/getting the bite.... 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #137676 7th Apr 2012 5:44pm
T1G UP
they all do it!
Post #137678 7th Apr 2012 6:18pm
excossack
Smashing! and there was me thinking of cunning ways to get some oil to the bearings without removing the box. 1999 Defender TD5 110
Regards
John M0VAZ
Post #137681 7th Apr 2012 6:21pm
changill
United Kingdom 2003 Defender 90 Td5 HT Bonatti Grey
A lot of them do it but shouldn't really. Mine does but only when its cold and first thing in the morning. I find dipping the clutch, selecting nuetral and starting the gear selection process stops it. After the first 400 yards all is normal. Only Alcohol Can Save me Now
Nanocom Available in the North West
Post #137725 7th Apr 2012 9:43pm
excossack
After mine has sat all night or all day at work it makes the noise other than that is quiet.
Is there any adjustment on the piush rod that might help? 1999 Defender TD5 110
Regards
John M0VAZ
Post #137732 7th Apr 2012 10:22pm
changill
There is no adjustment for clutch release bearing problems. But there is adjustment on the clutch master cylinder rod to ensure the clutch isn't engaged when the pedal is up and is fully disengaged.
Is the noise you are getting the clutch not disengaging?
It should be 140mm from bottom of clutch pedal rubber to floor with all mats up. Check that.
If mine made a noise after a clutch change I would prob take it back! The clutch release bearing shouldn't make a noise. Especially when new. Only Alcohol Can Save me Now
Post #137760 8th Apr 2012 9:19am
noworries4x4
T1G UP wrote:
they all do it!
+1
Its not actually the release bearing it is usually the spiggot in the flywheel, which even still makes a noise after you strip it back out and coat in copperslip, what causes it is wear in the gearbox input shaft bearing allowing the shaft to move slightly as the clutch is engaging.
Mine did it for years. If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle
Weekends MY 12 L322 4.4 TDV8 Vogue
No Worries 4X4
Post #137763 8th Apr 2012 9:28am
excossack
When I have my foot on the clutch and to the floor and in neutral I here a whiring noise, as I engage gear and bring up the clutch the whiring does get louder until I am off the clutch. I will check the measurement from the pedal to the floor.
When buying the clutch I made sure I went for a decent make - Valeo
I might email the supplier and ask their view as well. 1999 Defender TD5 110
Regards
John M0VAZ
Post #137765 8th Apr 2012 9:29am
wslr
The spigot bush shouldn't be lubricated, as it is sort of 'self lubricating'. It should be changed with every clutch change, otherwise you end up having to live with the noise. If the bush was quiet before the change, you can find it gets noisy as soon as the new clutch is in.
The gearbox input shaft and splines shouldn't be lubricated either, according to the book.
Post #137855 8th Apr 2012 4:07pm
excossack
The clutch pedal is about 145-147mm from floor to the bottom of the pedal
The noise was present before the clutch change. 1999 Defender TD5 110
Regards
John M0VAZ
Post #137863 8th Apr 2012 4:50pm
