![]() | Home > Maintenance & Modifications > QT diff guards |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2497 ![]() ![]() ![]() |
Have one in the front. Rock solid and very well made to sail over rocks. Heavy though. Puma 110" SW
............................................................. Earth first. Other planets later Last edited by MK on 6th Apr 2012 10:05pm. Edited 1 time in total |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20967 ![]() ![]() |
I expect they are but at least that will mean it's strong. Do you have any pictures? I only have the clamp on £20 - £30 ones right now and I doubt they'd mke much difference and certainly wouldn't act as a slider. |
Denis Member Since: 28 Dec 2010 Location: prairie Posts: 58 ![]() ![]() ![]() |
I have not QT but similar guard on front and plan to fit another to rear diff. Clamp on guards sometimes tend to turn when hit. Puma 110 |
MrFlips Member Since: 27 May 2009 Location: Cardiff Posts: 682 ![]() ![]() ![]() |
I've got QT guards front and rear, and they're excellent. They're pretty much bomb-proof, and are probably the first thing I would fit on any new Defender.
![]() 2008 SWB Truck Cab 1952 80" Soft top |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2767 ![]() ![]() |
I have them front and rear as well, as above very nice well-made bits of kit.
Important to have one on the rear as you're just as likely to reverse over something nasty, mine has a protector for the diff pinion as well on the rear which is handy. Clouted both of mine on Welsh rocks and English tree stumps and they've both done their jobs well ![]() My front one will get removed when I finally get around to swapping the front axle casing out, but only because the new casing will have a heavy-duty sump pan on it which negates the need for a diff-guard ![]() |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
agree with all the positive points, front and rear, just don't paint them a nice colour to show them off, they look crap very quickly, black waxoyl to stop the scrapes rusting every time,
unless your a chav ![]() Mark |
![]() Click image to enlarge Puma 110" SW ............................................................. Earth first. Other planets later |
Now that does look good! As someone mentioned I don't think the clamps ons would be much use anyway even if hit. |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
I had the full ones on front and back of my truck but now have the d44 ones
Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
I know the one's they are either Red or black only trouble is they are weld on which is out the question for me but no doubt brilliant and look great! |
Never bashed the rear diff in 20 odd years off offroad driving.
Nor have I in a mere two years but I guess there is always a first time. Wales with plenty of rocks and granite would be the sort of area to watch I would imagine. |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Front Diff:
![]() Click image to enlarge ![]() Click image to enlarge Rear Diff: ![]() Click image to enlarge ![]() Click image to enlarge I had to ream out one of the mounting holes on the rear one to allow it to fit as the hole was out by a ba** hair. |
So other than the one mounting hole issue you had they're a simple bolt on / off?
