Home > For Sale & Wanted > WANTED Warn 9000 0r 9500 Winch
noworries4x4
My winch has siezed up any one got one sat around wanting a new home ?? If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle
Weekends MY 12 L322 4.4 TDV8 Vogue
No Worries 4X4
Post #136348 2nd Apr 2012 7:26pm
Zagato
May still able to get a new M8000 for £550 if you do a Google search Wink Two companies were doing them for that a while ago! I have a cover for one if you do, it's mint of course Laughing
No joy in renovating your old one, probably not much, Glyn knows about winches!
Post #136449 3rd Apr 2012 8:50am
noworries4x4
Winter salt has corroded the ally cassing and the motor bearings are a propper mess, linings on discs blistersd and distorted. Cheaper to find a new one If everything is under control you are not going fast enough.
No Worries 4X4
Post #136565 3rd Apr 2012 5:40pm
jwhat
Ireland 2008 Defender 110 Puma 2.4 DCPU Keswick Green
Wow that sounds bad, I'll be getting a cover whenever I get my winch so. Tdci 110 DC
Post #136569 3rd Apr 2012 5:52pm
Yup, that's the trouble with the cheaper Warn winches. Although I have a 9000 on the Disco, I would never buy another - Superwinch Husky is the way to go.
Post #136573 3rd Apr 2012 5:57pm
noworries4x4
I am looking at either the goodwinch g5 9500i from David Bowyer or a Champion winch from Extream both the same sort of money. If everything is under control you are not going fast enough.
No Worries 4X4
Post #136615 3rd Apr 2012 7:41pm
Projectblue
Well that's an easy answer.
1. Goodwinch are brill and David Bowyer is great to deal with - have a look at the TDS Goldfish.
2. Champion are cheap and there's a lot of information about Extreme and the owner kicking around if you care to look Thumbs Up
Post #136700 3rd Apr 2012 11:15pm
noworries4x4
Good winch is most likely the route i am going down just cheking that it fits my bumper with out to much drilling and or cutting.
My heavy duty springs and anti roll bar are coming from Extream, i get on ok with them no problems with any of my srings on the TD5 or this Puma. The new one i am going for bigger roll bar than last time and slightly heavier springs than last time. Should be good. If everything is under control you are not going fast enough.
No Worries 4X4
Post #136703 3rd Apr 2012 11:38pm
excossack
I've got a Goodwinch 12000 and its worked well winching out stuck rally cars! 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #136730 4th Apr 2012 8:32am
