Home > Maintenance & Modifications > nuts & gaskets
mr_tdi82
United Kingdom 2004 Defender 90 Td5 HT Zambezi Silver
nuts & gaskets
does anyone know if i'll need to change the hub nuts and drive gaskets when changing discs and pads on td5?.
I know in LRO it says about changing them, but just spoke to another garage who wanna charge double price of paddocks and even they were unsure which hub nuts i may have.... said i may have double nuts???? know im slightly confused
Post #136522 3rd Apr 2012 3:53pm
MK
I think you are right. The Td5 has 2 nuts. I think you may need to change just the washer at the most. Try post it on the Td5 section. Puma 110" SW
Post #136531 3rd Apr 2012 4:42pm
Fifth Horseman
Just done the same job myself, but on an '07 Puma - you definitely will need to replace the gaskets, they are easily torn but cheap. The hub nut is either a double one with a washer which is folded to retain the nut (new washer required), or a single staked nut which needs to be replaced.
Landrover state that the drive flange bolts should be replaced every time, (they are 10.9 high-tensile bolts and an absolute bitch to remove if one breaks - DAMHIK..)
Post #136536 3rd Apr 2012 4:56pm
Fifth Horseman
It was the late TD5s that had the single nut IIRC - a dealer parts counter should be able to tell from your vehicle's VIN or reg no. (Or anyone with access to Microcat)
Post #136537 3rd Apr 2012 4:56pm
Fifth Horseman
[deleted - double post Embarassed]
Post #136538 3rd Apr 2012 4:56pm
