![]() | Home > Off Topic > Any D3/D4/RRS/FFRR Owners Interested in these ????(NOW SOLD) |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1196 ![]() ![]() |
I know, I know they should be in the for sale bit bit they are not for a Defender and not sure about price so using the hated words used on here "gauging Interest"
Set of 4 19" Rims c/w Goodyear MTR "G4" Tyres 3 with 7.5mm left 1 with 9mm left replaced after a blow out on a French Autoroute. Some light scratches to 1 rim not kerbed just off road marks. Excellent grip even on wet tarmac, just a bit iffy on side slopes as every one knows. ![]() Click image to enlarge I am looking for about £650 for the lot c/w rings to fit to P38 or Disco 2 if you want. Full set of tube style wheel nuts and key to operate them. They cost new £1,400 the lot somewhere in Warwick. I think it was Silverline doing a deal a few years back. If everything is under control you are not going fast enough. Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 Last edited by noworries4x4 on 14th Apr 2012 7:49pm. Edited 1 time in total |
If someone was going mad they could even put them on a Defender with a set of those wheel adaptors that were about a couple of years ago, might stick outside the flares abit though. If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
Just advertise them on the disco 3 site they will sell straight away.
![]() 110 HCPU Tipper |
Willy if you could chuck a link over it would be much apprieciated many thanks as i am only registered on Defender 2 If everything is under control you are not going fast enough.
Will do Original Member Pie n Pea Club.
110 HCPU Tipper |
Many Thanks Willy Ta
![]() Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
marsie Member Since: 18 Nov 2011 Location: sheffieldish Posts: 535 ![]() ![]() ![]() |
they would fit my defender without adaptors
![]() ![]() Paul |
You must have D2 or P38 axles under it then If everything is under control you are not going fast enough. Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
Yep,modded D2 axles
![]() ![]() Click image to enlarge Paul Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
19" wheels would fill those arches better
![]() ![]() I know Wildcats use the D2 axles the front casting and ball joints are even stronger than 7 bolt 110 swivel housings but dont see the advantage of converting them under a Defender. The hub bearing assys are a pain. If everything is under control you are not going fast enough. Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
We run them on our challenge cars as well. like you say-massively strong and 4" wider than stock 90/110 axles(my axles are now exactly the same width as before but without wheel spacers) but other than that no real benefit on a road car. Doing car as a rolling advert so will have plenty of mods.Also have a mate in the dealers that changes D2 bearings when they get a ABS faults but mine hasnt got ABS so have a ready supply of suitable hubs/bearings
![]() Paul |
Just changed all the corners on the P38 above they had all gone noisy at 130Thou, i went down the cheats route, dealer hubs at £350 a corner i don't think so, smashing the hubs to pieces in a press where the bearings are glued in did not fancy that either so got mine from a low mileage smashed up one, just praying it was not kerbed heavily in the accident but they are silent at the moment. If everything is under control you are not going fast enough.
I have not had any interest on here so now listed on ebay for 7days from Sat 7th for 7 days but if anyone wants them for more than £650 i will remove them ok If everything is under control you are not going fast enough.
http://www.ebay.co.uk/itm/130677627101?ssP...1555.l2649
This is the link if anybody wants them If everything is under control you are not going fast enough. Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
Well the ebay colour has just gone green someone has met the reserve @ £600 with 6 days to go. If everything is under control you are not going fast enough.
