![]() | Home > Puma (Tdci) > fault code |
| Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673
Use BAS' website: http://bellautoservices.co.uk/ -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged
Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
| The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459
P0404 Exhaust Gas Recirculation “A” control circuit range/performance
P0100 Mass or Volume Air Flow A circuit P1103 Mass Air Flow Sensor in Range but higher than Expected P0299 Turbocharger/supercharger A underboost condition. P0234 Turbocharger/supercharger A overboost condition P1402 Exhaust Gas recirculation metering Orifice Restricted |
sound like you need a new EGR
| nivmargalit Member Since: 19 Apr 2011 Location: under the sun Posts: 30
Thanks you all.
First I will try with clening the EGR, if it whont help I will change it. I found this site : http://www.permoveo.ltd.uk/tabid/123/Diagn...fault.aspx |
| Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Does the fault code reader differentiate between tested and untested dtc's? If there is no obvious degradation in engine/fuel performance, or any strange sounds emanating from the EGR on shut down, I would say the codes you have listed are normal untested dtc's which will clear themselves after 40 ignition cycles, unless they reoccur within the 40 ignition cycles, but as they are untested this is not an issue. I would only be concerned if the MIL was illuminated or the fuel use had increased significantly. Some DTC's taken from my Puma over the last 2 years:
NANOCOM - PUMAENG.APP - PUMA ENGINE fault file 0404 - 72 Exhaust gas recirculation (EGR) control circuit range/performance --- 0404 - 73 Exhaust gas recirculation (EGR) control circuit range/performance --- actuator stuck closed 0299 - 00 Turbocharger A under boost condition --- 0100 - 29 Mass or volume air flow A circuit signal invalid --- 1103 - 00 Mass air flow (MAF) sensor in range but higher than expected --- 1402 - 17 Exhaust gas recirculation (EGR) control valve metering orifice restricted circuit voltage above threshold --- 0234 - 00 Turbocharger A over boost condition As you can see above I have had at some point or other the same codes you have listed and my Puma still runs like a little sweetie with them. Below is an explanation of DTC's I did in another post:
HTH Brian. |
Thanks Brian,
I do not have any change of fuel or strange noise |
