Home > Td5 > Serpentine belt adjustment....
Gareth
How does the serpentine belt adjust?
Mine is squealing loudly when the aircon is working. Its not long since been replaced by the previous owner, so I want to check the tension. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #134794 27th Mar 2012 2:54pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
You don't adjust it as such. There is a tensioner pulley (bottom left of the engine as you look at it from the front) which maintains a steady pressure on the belt. Essentially it's a pulley mounted on an arm with a powerful spring behind it.
Post #134800 27th Mar 2012 3:54pm
landy andy
You can "force" the tensioner into the belt, and this keeps tighter than just releasing the adjuster. Trick I learnt from land over tech Thumbs Up
Andy
Post #134874 27th Mar 2012 8:25pm
Gareth
Ok, I will have a look at that method. Its calmed down a bit now. 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #134900 27th Mar 2012 10:40pm
changill
United Kingdom 2003 Defender 90 Td5 HT Bonatti Grey
Might you need a new tensioner? Only Alcohol Can Save me Now
Nanocom Available in the North West
Post #136368 2nd Apr 2012 8:52pm
