Home > Maintenance & Modifications > Rear Work Light
robpenrose
Rear Work Light
Can anyone recommend a good work lamp. I would like to add one to my roof rack on the rear, but not sure which one to go for. I would like an LED type so found the one below in a link. Im not sure how it would look thougth and would only allow movement in the up down direction. I would probably mount two, one on either side, or maybe one big one which can be pointed in all directions.
When my vehicle was built, they must have put two of the LR wiring kits in. I utilised one for the spot lights on the front, but have one spare, so would probably extend it and use it for the rears.
http://www.autoelectricalpartsuk.co.uk/pro...ltage.html
Any recommendations or advice appreciated.
Rob Current:D4 HSE
Gone: BMW Z4MC
Gone: Defender TD5 90 CSW
Previous: Discovery TD5 ES (Gone)
Post #134736 27th Mar 2012 10:47am
Here is a good selection: http://www.devon4x4.com/index.php?option=c...;Itemid=14
Personally I'd consider SKU: IPF816HCS or WL43
The IPF lights come as a pair and have a unique wiring kit supplied and the round LED type is single unit but with a hollow fixing bolt for easier cable routing. Thumbs Up
Post #134746 27th Mar 2012 11:08am
Our AlienXplorer LED lightbars are over 50% cheaper ..... we have a 7.5" model which fits neatly centered over the rear washer jet or in the 'standard' space on either side of the hardtop
http://www.farrowsclassics.co.uk/alienXplorer-L-E-D-Lightbar.html
Post #134748 27th Mar 2012 11:11am
robpenrose
Thanks Chaps.
Why do you have to have a unique wiring kit? Surely the LR one would work...
Liking the 7.5 inch LED light Bar Matt. Do you have any pictures with any installed on a vehicle? Would it give a good light output behind the vehicle?
Rob Current:D4 HSE
Gone: BMW Z4MC
Post #134752 27th Mar 2012 11:22am
Hi Rob,
These really are incredibly bright !
There is a write up from one of the guys at my local LR club who bought two for his work truck here:
http://www.twinaxle.com/phpbb/viewtopic.php?f=27&t=801
Post #134757 27th Mar 2012 11:41am
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
Could one of these be used as an additional reversing light? maybe mounted down on the crossmember somewhere, or would it be better as as reverse/work light maybe mounted high up.
I see "only for off road use" does that mean when used on the front (or front and rear?)
DJ 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #134759 27th Mar 2012 11:48am
The 'Off road use only' is specifically when used on the front.
Mounting higher up will give a better spread of light and put them further out of harms way, having said that I've mounted one of these between the rear lights on my trayback as a reversing light (but that is about chest height)
Post #134760 27th Mar 2012 11:59am
I can't find a pic of the rear of the Trayback right now but here is one of a 7.5" lightbar fitted to the side of my Trayback for a recent night punch hunt (and a 42" above the front screen)
Post #134762 27th Mar 2012 12:10pm
robpenrose wrote:
Thanks Chaps.
Rob
Sorry, should have said specific. IPF supplies a wiring kit with the two lights. Or of course you could do your own Thumbs Up
Post #134768 27th Mar 2012 12:40pm
Are these units spotlight or floodlights (or somewhere between the two?). They are a really neat size and I was thinking of bumper mounting them below the main lights if they work as spots. That way, it avoids the problem of putting something in front of the protruding A/C grill. Darren
Post #134774 27th Mar 2012 12:57pm
Hi Darren,
I think you have probably accurately described them as 'somewhere between the two', did you look at the link on 'Twinaxle' ?, Peter has posted up some pretty good pictures with cones at various distances
Post #134777 27th Mar 2012 1:05pm
The pictures were 'temporarily unavailable' when I tried. I'll have a look later. Darren
Post #134779 27th Mar 2012 1:12pm
mobilecentre
Not as powerful but smaller. Flood or Spot beam patterns available.
http://www.defender2.net/forum/topic7969.html
Post #134876 27th Mar 2012 8:31pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Recommended ... a pair would be the dogs b***oxs Thumbs Up Guns and Landrovers .... anything else is irrelevant.
Post #134877 27th Mar 2012 8:37pm
Rigid Industries LEDs for sale by Devon are pretty tough, and there's a good selection right up to 50" Thumbs Up
Made in the USA .. (ie Not Chinese)
Post #134881 27th Mar 2012 8:44pm
