![]() | Home > Technical > TD5 fuel pump on the way out? |
| Nick T Member Since: 29 May 2011 Location: Bolton Posts: 203
Having exactly the same problem. Pressure tested pump-ok. Injector seals are prime suspect now.
| Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478
yep highly recommend changing the injector seals/washers, my 90 02 with 50k mileage suffered the same problems two weeks back, the whine got louder and the car got harder to start at one point it didnt want to start without me pressing down the accelerator pedal down fully whilst turning the key, i thought the worst the pump but lucky enough changed the seals and now is as good as new
| gambit Member Since: 26 Mar 2011 Location: Sussex Posts: 79 |
Changing the seals, is that a big job? Specialist tools required?
Thanks Andrew |
basically
remove engine cover remove rocker cover disconnect harness ontop undo and remove the injectors a bar with a hook is needed as they can be a pain change the sills one by one jack one wheel up and turn the wheel turning the landy over getting each injector to the maximum adjustment and do up put it all back together job done im sure if you do a google there would be a pictured guide matey |
| cradgebank Member Since: 30 Dec 2008 Location: Nottingham Posts: 308
Check the mesh screen filter on the fuel pressure regulator, located on the rear of the cylinder head.
I had the same symptoms once and after replacing the fuel pump to no avail, checked the FPR filter and found it blocked with black sludge. Richard Either a 90, 110 or 130. Discovery 5 |
Cool - thanks
Will have a look - changing the seals is much more wallet friendly than the pump |
| wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581
And don't forget to follow the workshop instructions including how to set bump clearances, otherwise you'll end up with a smashed up injector unit. |
