Home > Off Topic > Which chain saw
Page 1 of 3 123>
JJ
United Kingdom 1987 Defender 110 V8 Petrol CSW Corris Grey
Which chain saw
I am building a wall with old railway sleepers and being a cheapskate went for the cheaper section rather than the shiny ones . What I wasn't expecting was for them to be different widths Embarassed so I need to make notches on the ends to slot into the RSJs I have had cut to length. I was going to buy a small chain saw any way to have in the back of the defender for those early morning tree in the road events. ( quite common in autumn ) .
Does any one have any opinions on this , I should hope there is a wealth of experience on this forum in this field.
Budget would be £250 ish could strectch to £300.
Any advice would be appreciated.
Post #133992 24th Mar 2012 6:28pm
K9F
I built a gazebo out of old railway sleepers (picture below whilst under construction) I bought a hand held Dewalt mains circular saw. Best tool for the job to get straight even cuts....
Fekete sometime ago was kind enough to give me a 14" Partner E351 chainsaw, also worth it's weight in gold. If they're used sleepers watch out for the metalwork in the ends....
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #133997 24th Mar 2012 6:36pm
I built a retaining wall in my garden from sleepers a couple of years ago - approximately 10 sleepers high by around 15 metres long, which used 100 of them. I bought an 18 inch chainsaw from eBay for less than £100 that worked (and continues to work) perfectly.
You can spend hundreds on a Stihl or similar, but unless you are using it professionally, it's really not necessary for this sort of thing. Darren
Post #133999 24th Mar 2012 6:40pm
Zagato
STIHL Thumbs Up Has never let me down, easy to maintain. Make sure you know what your doing with one though Shocked Good idea to go on a course Wink
Post #134000 24th Mar 2012 6:41pm
Oh, I invested in some safety gear too: trousers, gloves, mesh visor and ear defenders. Chainsaws can bite! Darren
Post #134020 24th Mar 2012 7:08pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
I did my railway sleeper raised beds the same but with a reciprocating saw, some of the really hard sleepers cut much better this way without constant sharpening of chains and gallons of juice. If you really want a chainsaw look on ebay there is a man who sells ex military Husqvarna proffessional 181 (81cc) saws in a box with spares for a real good price I got one a while back and its been superb.
EDIT, sorry he's sold the lot, they were to big for you anyway Whistle Original Member Pie n Pea Club.
110 HCPU Tipper
Post #134030 24th Mar 2012 7:41pm
RED-DOT
I got a Huskie 14" off a garden centre off Ebay for about 33% off RRP. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #134066 24th Mar 2012 9:00pm
JJ
Thanks Thumbs Up
So in summary I only need a cheap one or an expensive one or not at all Rolling with laughter
Post #134121 24th Mar 2012 10:42pm
rossy
B&Q sell a nice cheap unbranded one. Zag would turn his nose up at it but as long as you get a mixing bottle (incorrect 2SO mix ratio is often at the root of problems with these things) for normal domestic use they are very good
Post #134146 24th Mar 2012 11:21pm
RFT
United Kingdom 2010 Defender 130 Puma 2.4 HCPU Zermatt Silver
Even for occasional use I'd always go for Stihl. Reliable and easy to maintain.
With seasoned wood such as old sleepers most chain saws will not deliver enough chain oil, (green wood does not absorb as much oil off the cutter bar as seasoned wood) so have an old tin with cheap engine oil in and dip chain bar in every couple of cuts.
If you are planning to always cut dry seasoned wood look for a joiners chain saw. 130 Puma HCPU with an Artica 240LR Demountable Camper
Post #134162 24th Mar 2012 11:48pm
Lishlandy
England 2012 Defender 110 Puma 2.2 X-Tech LE Orkney Grey
Just got a new Stihl, wouldn't look anywhere, just goes through everything like butter, never had a snatch back or loss of speed.
Within your budget too for a 16" ===================================
Steve
90 xs sw in Stonoway Grey - Sold
110 USW X-TECH
Post #134170 25th Mar 2012 12:39am
The Musketeer
United Kingdom 1988 Defender 90 Other HT Cairns Blue
If your using it a lot its worth buying something reasonable but for that job I'de stick to something below £100 from ebay!
Are your legs worth more than £50? If so buy some trousers too Wink
Just adjust the oiler Rolling Eyes Good things come to the wild and free
Post #134171 25th Mar 2012 12:47am
cradgebank
England 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Stihl or Husqvana everytime Thumbs Up
Consider hiring one if you only need it for that particular job, although I seem to remember some legislation coming into effect regarding the hiring of saws, you may need a safety ticket or something now. Richard
Either a 90, 110 or 130.
Discovery 5
Post #134179 25th Mar 2012 2:04am
Zagato
A friend was given a cheap Draper chain saw for his birthday, it won't take heavy use I shouldn't think but it did the job on some dead logs OK.
Sleepers will pretty much kill your chain in no time so a sharpening kit is a good idea. I don't bother now and just charge the client for a new chain each time....
Post #134211 25th Mar 2012 8:33am
As already mentioned, this is easily adjustable. The sleepers I used were European hardwood (because they're a slightly larger size that suited my needs) and my chainsaw handled them without any problems. I did blunt two chains, but that's partly because I couldn't be bothered to mess around sharpening the first one. Darren
Post #134228 25th Mar 2012 10:13am
Page 1 of 3 123>
