Home > Td5 > handbrake adjustment
alanhid
Scotland 2006 Defender 90 Td5 XS CSW Bonatti Grey
anyone explain in an "idiots guide" how to adjust a Def TD5 my06 handbrake?
Cheers Smile Life is not a rehearsal!
Def 90td5 CSW xs 2006
Post #133952 24th Mar 2012 2:21pm
Jack up one rear wheel (After chocking the front ones)
release handbrake
Crawl underneath with a 17mm socket.
adjust the nut on the back of the handbrake drum, one notch at a time, until the drum/rear prop won't turn, slacken off one or 2 notches.
get back up into the cab, pull the handbrake on and see if it feels "right" (should be 3 or 4 clicks from off to fully on)
Post #133998 24th Mar 2012 6:37pm
alanhid
Thumbs Up Thumbs Up thats what I call an idiots guide............works for me Thumbs Up Life is not a rehearsal!
Post #134024 24th Mar 2012 7:14pm
chiefstoker
England 2005 Defender 90 Td5 HT Zambezi Silver
Can you adjust the position of the handbrake light switch? 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy
Post #134082 24th Mar 2012 9:31pm
Not easily.... the holes for the fixing screws for the switch are drilled into the mounting plate for the handle, so you'd have re-drill, or you could bend the little arm that presses the switch. looks a bit flimsy though, so be careful!
Post #134189 25th Mar 2012 7:35am
chiefstoker
Cheers DJ, its just that my lever has to be totally home for the light to go out 2005 TD5 90 Hard Top
Post #134210 25th Mar 2012 8:31am
WarPig
Exactly the same on my 300tdi Confused
Post #134402 25th Mar 2012 11:11pm
ZeDefender
and my MY11 Puma Thumbs Up Tell someone you love them today because life is short.
Post #134416 26th Mar 2012 6:53am
chiefstoker
I shalln't lose any sleep over that particular issue then Thumbs Up 2005 TD5 90 Hard Top
Post #134498 26th Mar 2012 2:25pm
Merlin
While you're at it, put some insulation on the wire. It rubs on the mounting and will eventually rub through.
Merlin
Post #134568 26th Mar 2012 7:05pm
ZeDefender
a-just adjusted mine (pardon the pun). Took less than 10 minutes and I was shocked how far out it was Shocked
Even though mine's a Puma with a cable-actuator, I followed an older Haynes handbook - tighten the adjusting nut until the jacked wheel won't move (conveniently kickable from underneath) then back off the nut 1 and 1/2 turns. Now it takes 3 handbrake notches from full-off to full-on Thumbs Up
Bloody German dealers said 5-7 notches and near-vertical lever is "standard" - bloody idiots Evil or Very Mad
Still have to see if the clattering goes though - I will report back...
p.s. I honestly believe 6 months membership of this forum should be compulsory before buying a Defender Rolling Eyes Tell someone you love them today because life is short.
Post #134722 27th Mar 2012 9:28am
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
ZeDefender wrote:
............p.s. I honestly believe 6 months membership of this forum should be compulsory before buying a Defender Rolling Eyes
what a great idea. Thumbs Up BM52
Post #134860 27th Mar 2012 7:59pm
