Home > Puma (Tdci) > Mad, over confident or stupid.....
Am I mad to potentially risk my warranty?
Yes sure am !
81%
 81%  [13]
No can be sure the work is done properly and it's a small risk!
18%
 18%  [3]
Total Votes: 16
Jonno
United Kingdom 2011 Defender 90 Puma 2.4 HT Santorini Black
Well my 2011 90 HT is just about ready for its first annual service. Having seen some of the quotes often mentioned on here, I'm considering DIY.
Costco are currently offering the Castrol Ford spec oil for about 17 quid for 4 litres and a genuine filter is about 13 quid from my local main dealer (top dollar I know, but think best to stay with approved parts for now).
My thinking is, I can do the engine oil and main gearbox, transfer box and diffs for a fraction of the price a main dealer service would cost.
I'm considering keeping the thing long term as I just like it and nothing has gone wrong so far, touch wood.....so damaging residuals doesn't really worry me.
The last car I self serviced from new was a Clio DCI 100 and the clutch slave cylinder died at about 18 months, 40,000 miles, I went to the local main dealer and they took great pleasure in telling me to Censored off as I had not had it serviced. At this point I contacted Renault uk who agreed the warranty could not be voided as the clutch cylinder lifespan would not be affected by a having the car main dealer serviced, as they wouldn't touch it!
So I'm hoping it anything does pop LR would be as understanding and only try to wiggle out of things directly affected!
Now where do I sign up for the loony bin..... Confused
Post #133866 23rd Mar 2012 11:26pm
LR90XS2011
you pay your money and take your chance
I have managed to get a very big discount on my first service from a francise dealer so will be using them until its 3 years old and then at that point it will be mods and self service or an even cheaper indy
there is a web site that finds all the francise dealer prices and compares them but I cant find it now but used it and then asked for price matching (50% off what i was originally quoted) DEFENDER 90 TDCI XS,
Post #133883 24th Mar 2012 7:04am
110SEB
Re: Mad, over confident or stupid.....
Jonno wrote:
...nothing has gone wrong so far, touch wood.....
Famous last words. Drivetrain servicing not done under warranty is the best excuse for LR to tell you to F off when you need a new gear box, transfer box, clutch. Let alone a new vacuum pump, steering box etc.
Why risk it for the sake of £200 quid? The stealers will do you a deal. Why not supply your own cheaper oil and filters to save a few quid?
Post #133884 24th Mar 2012 7:33am
EU Law allows Indy's to service cars and as long as the genuine parts are used, the warranty is still valid. Having said that, you still need to get it into a land rover workshop for their corrosion inspection but they can't charge too much for that.
get a price from an indy and take it to the dealer and see if you can't have a deal ? of course if you have made any mods to engine, exhaust, suspension etc they should not be expected to honour that aspect of the vehicle.
so, not mad, not over confident or stupid - just wanting value for money Thumbs Up
Post #133886 24th Mar 2012 7:49am
BigMike
Indy all the way. And as BPMan says, get LR to do the corrosion check (which they shouldn't actually charge for).
Seems that £500 quid is the usual price for a first service at a dealer which is utterly scandalous since all it is is an oil change and diagnostic + corrosion check.
A good relationship with an indy is worth its weight in gold since they need and want your business.
Post #133890 24th Mar 2012 8:31am
Zagato
£330 is the cheapest I have heard of, I paid £380 without a haggle.
As well as the corrosion check, they also do a 40 point check which is a pleasure to watch Very Happy they go right through the vehicle checking doors work (alignment, shut adjustment is OK!), grease the catches, they check prop shafts for free play, main nuts underneath, handbrake, leaks from G/B, TB, power steering, other cylinders, any rubbing of hoses, chaffing of wires etc, belts tension, wheels off for brakes, leaks etc, drain fuel filter, steering rods, tightness of bolts, mounting rubbers, etc etc and a final test drive.
I forked out the extra firstly for the peace of mind it was done well as I know the guys do a good job and they don't mind you hanging around for a chat and to see what they do. Secondly I have a noise coming from the rear which they checked out at the same time and thirdy I don't have an independent near me.
I save money in other areas so don't mind paying the extra to have it done properly. When the warranty runs out and any lengthy labour jobs are needed it will be straight over to an independent Wink
I would go to an independent that you trust if you don't want to pay the extra and are not sure what your dealers work is like Thumbs Up
Post #133895 24th Mar 2012 9:02am
rossy
jonno I'm totally in the same frame of mind. I can change oil, filter, grease props, and change diff, Tbox and Gbox oils and hate paying silly money when most of the service schedule can be done at home for about fifty quid.
Unfortunately the anecdotal evidence is such that LR will look for the absolute slightest reason to walk away from potential warranty claims so begrudgingly I'll just have to cough up for a couple of years. Its not quite as dear here with Toppings in Eniskillen charging £ 250 all in for 12k service or Bradleys in Galway taking € 330 off you. My father in law paid Lookers in Chelmsford over £500 for the first service ! Thats one expensive oil change
Post #133907 24th Mar 2012 9:31am
K9F
MAD! Is this thread for real? Whistle BP man wrote 'Value for money' my question is would you self-service your Defender Ice even if out of warranty? Thought not! Independant all the way! Why lose out on a couple of years warranty for the sake of saving a few quid? Bet even Red Dot shells out for a dealer/indy service when it's due! (No offence RD! But you did call yourself a Tight Jockanese git! I'll have what your missus has removed by the way if she does 'go for a smaller pair!' Thumbs Up ) Think the poll results speak volumes!!!!
Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #133917 24th Mar 2012 10:39am
JJ
United Kingdom 1987 Defender 110 V8 Petrol CSW Corris Grey
Haggle for a better price from the nearest dealer and get a feel for how good or not they are. It is all down to the individuals that work at a particular garage, as in all aspects of life some people care about their standard of work and some just want the money for beer at the weekend.
The attitude of the service manager will tell you a lot about the staff that work for him/her.
After 3 years if they have done their job well you may even stay with them !
Post #133919 24th Mar 2012 10:47am
pom
you dont have to use a dealer for service you can use who you want. EU law.
It's upto them to prove whoever did the service was not able to pour oil into a hole in the same way that they do.
Pom
ps I'vr yet to deal with any LR or Audi dealer who isnt a Liar, scammer or just plain useless.
Post #133922 24th Mar 2012 11:07am
ericvv
Good luck with DIY or an independent.... Look at the following extract of the LR warranty terms. There is much more to a first service than just an oil change. The LR maintenance schedule has about 49 points which need to be done/checked. Try to proof that an independent, let alone yourself did all that. And as to DIY, how will you complete and stamp the maintenance schedule at the right intervals, which is a requirement for warranty claims?
QQ
Owner's responsibilities
Your owner's handbook and service portfolio describe the proper care of your vehicle. Make sure that all the required maintenance is performed, including regular cleaning of bodywork, and that the materials used meet Land Rover engineering specifications. Failure to perform the required maintenance on a timely basis and in accordance with Land Rover's service intervals will invalidate warranty coverage on affected parts.
Make sure you present your vehicle to a Land Rover dealer/Authorised Repairer for any warranty repair as soon as practicable after a defect is detected. This will minimise the effect a defect has on your vehicle and the nature of the repair needed.
Be sure that receipts for completed maintenance work are retained with the vehicle and confirmation of maintenance work is always recorded in your service portfolio.
QQ You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #133949 24th Mar 2012 1:58pm
Tony
United Kingdom 2012 Defender 90 Puma 2.2 SW Keswick Green
Hi,
I'm not an owner yet (awaiting delivery of a 90 SW in April or early May) but when I asked the dealer about servicing costs he made it very clear it doesn't need to be done at the main dealer as long as 2 conditions were met to keep the warranty valid:
1. Genuine LR parts must be used.
2. The garage carrying out the work must be VAT registered.
From what I've read on the forum mine will be going to the main dealer initially, after 3 years it'll be going to an indy.
Tony
Post #133951 24th Mar 2012 2:18pm
K9F
Tony wrote:
From what I've read on the forum mine will be going to the main dealer initially, after 3 years it'll be going to an indy. Tony
Beats me why people wait? I have five dealers at a closer distance than the independant I use, I trust him implicitly with his expertise and standard of service and would prefer to use him every time, hence the reason I travel an hour and a half to get to him, instead of the ten minutes to my nearest dealer..
Whistle If you go through life with your head in the sand....all people will see is an ar5e!!
Post #133956 24th Mar 2012 3:04pm
As has been mentioned above, you don't need a genuine dealer to do your servicing to keep the warranty in check.
However, as I just found out with my shogun (engine trashed itself because one of the timing chain guides snapped off and fell into the timing gears) if you have any post warranty problems (as mine was, only just outside of warranty) any chance of a goodwill gesture by LR will (probably) be thrown back in your face, just as Mitsubishi did to me, claming "lack of loyalty to the brand"
eventhough we'd spent £22 odd thousand on it, which would pay the years wages for the silly bint who told me that! Rolling Eyes Evil or Very Mad
so, it depends on whether you want to keep your local dealer (or any dealer, or LR customer services) "sweet" after the warranty ends.
Post #133996 24th Mar 2012 6:35pm
Jonno
Well that's a pretty conclusive response!
I have a month to look around for a few quotes and decide, if I do play russian roulette I'll let you know the outcome, painful or otherwise !
My main "issues" are having worked in a main dealership (Not LR) several years ago to be honest anything would go in the workshop, the oil used in customers cars was the cheapest that could be bought at the time that was of the correct viscosity.(In some cases not even the right viscosity was used i.e 5-30 going in diesels when they required a heavier grade.
I worked in sales but got a good overview of general practices.
Jonno
Post #134038 24th Mar 2012 8:15pm
