Home > Puma (Tdci) > EGR % on my Ultragauge
Ashley110
South Africa 2012 Defender 110 Puma 2.2 SW Alpine White
I plugged in my Ultragauge this weekend.
My MY2012 Puma with less than 1000 miles is showing EGR % permanently as 20%.
Any ideas?
Post #133464 22nd Mar 2012 7:07pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
Mine shows if moving all the time unless (like for the last two weeks) I have the EGR closed patch in then it just shows 0% all the time. Sound like something is not right.
Post #133467 22nd Mar 2012 7:23pm
I've been watching my egr%, no engine mods and it's intersting to see what is going on. it's open more often that i thought it would be. seems if the engine is not being pushed, it's open a little.
i don't have any problems with performance or unusual sounds, clunks clicks etc i guess the engineers at land rover know what's best ?
Post #133490 22nd Mar 2012 8:28pm
john adam
France 2010 Defender 110 Puma 2.4 SW Keswick Green
I have a ScanGauge and the %EGR fluctuates all the time. For instance when the engine is running idle the %EGR ranges between 15% and 25%. I really do not know if this oscillation is due to the sensitivity of the instrument or the EGR valve goes like a crazy Rolling Eyes
Carlo 1971 88 Series IIA somewhere in Southern Italy
1989 Ninety stolen in Paris
2004 90 TD5 gone
2010 110 S Puma TDCI running
Post #133523 22nd Mar 2012 9:38pm
Caterham
is it fair to assume that once the egr finishes its self clean cycle when the engine is turned off the erg fully closes?
thinking about disconnecting the egr again for a while to so how the engines performs?
Post #133671 23rd Mar 2012 10:12am
Naks
Re: EGR % on my Ultragauge
Ashley110 wrote:
I plugged in my Ultragauge this weekend. My MY2012 Puma with less than 1000 miles is showing EGR % permanently as 20%. Any ideas?
Ashley, that doesn't sound right. Have it checked out --
Post #133675 23rd Mar 2012 10:54am
The Boy
I am running a standard tune with egr shut patch at the moment to see how it compares with running with it operating normally. Been three weeks so far and is not what I expected.
Post #133694 23rd Mar 2012 12:54pm
Naks
what were you expecting?
I ran that same map during a 6000km overlanding trip and it performed as expected --
Post #133696 23rd Mar 2012 12:58pm
The Boy
early days yet but it looks like fuel consumption has gone up which really surprised me and seems to be nosier than before. However like I said only been about three weeks so will give it another week and I have a bit of running about this weekend with quite a few miles involved so i reserve my judgement for another week.
Post #133699 23rd Mar 2012 1:03pm
4wheeler
Australia 2013 Defender 110 Puma 2.2 SW Chawton White
I have not used the EGR capability on my scangauge until an MIL warning came up 400km into a 4500km trip. The MIL went out after four start cycles and was good for another 1200km then came on again and went out and stayed out for the rest of the trip. I found that the EGR would run at 15-25% most of the time but would stick on 100% and stay there once or twice a day until I swithched off the vehicle and restarted it after which it would work in the 15-25% range again. No MIL was flagged when the EGR stayed at 100%. I could tell by ear when the EGR was at 100% as the engine did not sound sweet compared to normal running, especially under light throttle.
I replaced the EGR valve with a new one. It will be interesting to see what it does. I purchased a new EGR after the MIL came on just in case the original one failed as I was travelling in outback areas 900 km from a dealer. I am glad I did not replace it on the run as it was a little fiddly to do. Took about two hours to change but having done it once it would take 1/3 - 1/2 the time if I have to do it again.
Post #148866 6th Jun 2012 10:48am
AlisterC
Wales 2011 Defender 90 Puma 2.4 XS CSW Indus Silver
I hope I'm not jumping in here but would really appreciate some advice.
Recently got a 2011 2.4, and it does the " Chugga, chugga, chugga" thing when i switch the engine off.
Is that the EGR going through the cleaning cycle, and is it supposed to happen?
Many thanks
Alister
Post #148869 6th Jun 2012 11:38am
JSG
Many thanks
Alister
Yes, that's normal Thumbs Up John
2011 Tdci 110 CSW XS
Post #148870 6th Jun 2012 11:40am
Naks
AlisterC wrote:
Recently got a 2011 2.4, and it does the " Chugga, chugga, chugga" thing when i switch the engine off. Is that the EGR going through the cleaning cycle, and is it supposed to happen?
Yes, see  --
Post #148871 6th Jun 2012 11:40am
AlisterC
you guys are very cool, thanks for the quick response!
Post #148873 6th Jun 2012 11:42am
Lorryman100
Any ideas?
Is your 2012 Puma a 2.2? If so then you may get a difference in operation/readings to a 2.4 due to the DPF and ECU fuelling parameters. Also when you first plugged in the ultragauge what Protocol was identified? Mine was 11 Bit CAN on a 2009 2.4.
If it is a 2.4, again what protocol was recognized? Did you manually change the protocol settings by accident or intentionally?
Brian.
Post #148904 6th Jun 2012 4:54pm
