Home > My Defender > My 110DC has a new buddy !
Page 2 of 6 <123456>
Retroanaconda
twopoint6khz wrote:
Shouldn't be anywhere near needing a new cross member surely? Shocked
Release bearing, if it's just noisy I'd leave it, they really do all do that. Most only do it from cold.
Td5 rear crossmembers are just incredibly bad. Made from wafer-thin steel and full of mud/water traps. If you do replace it don't just stick another POS Td5 Land Rover one on. Get one from one of the companies making proper-thickness ones like MIB Components.
I have seen 2001/2002/2003 cars with gaping holes in the back of the chassis, funnily enough my 1993 110 was only just encountering some surface rust Smile
I don't know if they've improved it for the Tdci models, I hope they have.
Post #133239 21st Mar 2012 10:00pm
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
The reason I posted that was that my old V-plate 90 still had no visible corrosion anywhere on the chassis at 10 years old. The rear x-member was totally solid. Fair enough I looked after it, but I did off-road it and leave it covered in crap too. Didn't think they were that bad TBH, but I'm happy that mine was the exception to the rule Confused
New one seems pretty solid too, but that's only 6 years old.
Post #133242 21st Mar 2012 10:03pm
Retroanaconda
Indeed, it depends how it's looked after. I have a 1992 90 that evidently hasn't been in its previous life, so it's had a new rear crossmember and various other patches from me. A Td5 that has been looked after should still be OK, as yours proves Smile
But the metal is far thinner on a Td5, which makes them very prone to rotting through, And the design with that silly hole for the towing socket doesn't help things either.
Post #133246 21st Mar 2012 10:08pm
bob neville
The one I have got has never been offroad but it has spent the last 10 years in Portland so I would expect some problems with rust.
The rest of the chassis looks fine and two of us had a damn good inspection of it to make sure it was OK.
The guy who looked at it with me is just putting a new chassis on a series 3 and has had land Rovers since he could drive. His opinion was the same as Retro's, TD5 rear crossmembers are not good. He did fit a new one to a 110 and said it would have been better to put a new chassis on.
Thanks for the heads up on MIB Retro, just had a look on their site Thumbs Up
2013 Defender 90 CSW - sold
Post #133248 21st Mar 2012 10:12pm
bob neville
Picked it up Thumbs Up
Drives like a dream, not bouncy like the 90 Pumas I have driven but that could be down to the tired suspension.
Had time to look round before dark, rear cross member not that bad (has had an advisory for the last five years Shocked ), rest of the chassis looks good. Couple of areas of bubbling paintwork to sort and, bodywise, thats it.
I will have a galv chassis fitted this year.
Front and rear diff pinion seals are leaking, I will check the breathers at the weekend to make sure that is not the problem.
As twopoint6khz said, release bearing shuts up after 5 minutes so that is being left alone.
And the engine sound (without a decat and centre box removed - yet Laughing ) - fantastic Thumbs Up
The really bad point (apologies to dog owners - I have owned dogs for many years but not recently so am not biased) - the stench of wet dog inside Crying or Very sad
First job is to bin all the carpets, remove the seats and headling and give everything a damn good airing.
It is having rubber mats fitted throughout, probably get the Exmoor R380 set, not cheap but all I can find at the moment.
Overall, very happy - pictures at the weekend Thumbs Up
Post #133547 22nd Mar 2012 10:17pm
Bob
Sounds great Bob. Yes, carpets and dogs don't mix at all least of all wet ones Laughing Far easier to clean and keep clean having rubber throughout. Look forward to seeing your pics. Thumbs Up
Post #133551 22nd Mar 2012 10:24pm
chiefstoker
England 2005 Defender 90 Td5 HT Zambezi Silver
I never really understand why carpets are fitted to Defenders anyway Confused 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy
Post #133640 23rd Mar 2012 7:34am
bob neville
Here she is, back from the health farm and ready to be modified Thumbs Up
Post #145925 19th May 2012 2:29pm
Zagato
That's very nice, same colour, age as my last 110. I would have one over a TDCi 90 SW anyday Wink
Post #145932 19th May 2012 3:32pm
JSG
Nice Thumbs Up John
2011 Tdci 110 CSW XS
Post #145933 19th May 2012 3:32pm
wslr
How are you getting on with the exhaust note? Whistle
Post #146057 20th May 2012 10:23am
bob neville
I think it needs just a bit more growl Rolling with laughter
It is just about perfect and there have been a few comments already - all good Thumbs Up
Post #146129 20th May 2012 6:23pm
nice looking truck Bob ... Thumbs Up
Post #146201 21st May 2012 7:34am
bob neville
New pictures Thumbs Up
Progress has been slow due to having done my left knee in Big Cry
Work done.
New drivers and passenger doors fitted.
Steering guard fitted (Bearmach)
Silver CP replaced by Mammouth black version
Mantec snorkel fitted
All above from site sponsors Defenderbits Thumbs Up
New rear headling courtesy of site sponsors Duckworths - not sure if I should thank you or curse you Dan - it was a ****** to fit Laughing
All interior stripped of wet dog smelling carpet etc. rear fully sound proofed and rubber mat put in.
Top part of dog guard found and fitted.
Rock sliders fitted to replace sills.
CB installed.
All instrument lights replaced by LED's - what a difference Thumbs Up
Crystals and night breakers fitted, with stainless rims from Mobilecentre and new levelling motors installed.
Windscreen hinges replaced with new ones sprayed black.
Nato hitch and reinforcing kit fitted to rear cross member.
Start made on the body work. Not a vast amount mainly bubbling on the ali plus bimetalic corrosion under the old CP that has spread (you can see an area at the rear that has been taken back to metal and etch primed.
Still to do.
New wheels and tyres.
Winch and bumper.
New shocks and probably front springs.
Sound proof and finish rubber matting in the front.
Finish the paintwork.
I may also put new discs on when doing the suspension, the old ones will probably need replacing before the end of the year.
Getting there Thumbs Up
Post #153067 1st Jul 2012 5:43pm
22900013A
Looks very good Bob. I want that same type of snorkel for my 110 later this year, any recommendations on best place to get one?
Post #153069 1st Jul 2012 5:45pm
