Home > Td5 > Td5 Defender Missfire in Heavy monsoon rain |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 |
Hi: Have you got a RAI fitted?
21st Mar 2012 11:12am |
LRO53 Member Since: 07 Jan 2012 Location: Australia Posts: 16 |
RAI? i don't know what this is? |
21st Mar 2012 11:13am |
Sorry - Raised Air Intake.
21st Mar 2012 11:14am |
No it's just the standard factory side entry. |
21st Mar 2012 11:15am |
Check the air filter and see if it has been misshaped? Just thinking aloud, but dense air and water droplets hitting the hotwire MAF sensor could explain both the misfire and the sudden return to normal once the rain eased a little.
21st Mar 2012 11:18am |
Will check it now..
21st Mar 2012 11:19am |
This could be it? You can see straight through the filter..
Click image to enlarge Click image to enlarge [/img] |
21st Mar 2012 11:35am |
Is there any sign of there being water sitting in the bottom of the air intake box?
21st Mar 2012 11:53am |
Click image to enlarge Does not look like any water has got in? Still dust in the bottom. |
21st Mar 2012 12:10pm |
The air filter looks as though it has been wet at some point.
Can you remove the MAF sensor and just check to see if there is any debris either on the element or caught in the protective gauze/mesh? |
21st Mar 2012 12:40pm |
Click image to enlarge Looks ok to me. I will get a screw driver out tomorrow and remove it proper so i can see the other end. |
21st Mar 2012 12:58pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6046 |
With normal LR build tolerances, i'm suprised you never drowned inside your 90
21st Mar 2012 3:01pm |
marcusjclifford Member Since: 21 Jan 2012 Location: Scotland Posts: 7 |
My guess would be the air filter getting damp, when damp less air can be drawn through it so the engine is in effect strangled of oxygen so there is significantly reduced power. It wouldn't need to be so wet as to accumulate actual water in the air box.
I don't know if that would be enough to cause a miss-fire though. Once the rain stopped the air filter would dry quickly as air is drawn through it so it would not necessarily be still damp when you checked it, although as pointed out before it looks like it may have been damp in the past. |
22nd Mar 2012 12:19pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5429 |
Agree with above as I have suffered from the same.
The air filter gets damp, reducing the amount of air flow to the engine. In my case it also killed a two day old £100 MAF You can see that your air filter has been wet Andy |
23rd Mar 2012 7:59am |
