![]() | Home > Maintenance & Modifications > Horns! |
| The Musketeer Member Since: 07 Feb 2012 Location: United Kingdom Posts: 193
My horn (on the truck) is pretty, well, Fiat 500 like
I fancy an awooga horn. Is it loud and where does it fit, it doesnt look like it would get behind the grille? Good things come to the wild and free |
| RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2038
Where exactly is the horn located? Mine is beyond pathetic, either its
Looked through Rave but there's no mention of the horn and how to find it. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
Wouldn't you know it, just found out its behind the LH headlamp. Doh! 2016 D4 HSE
| Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1751 |
Your horns are located behind the headlamps on Td5 onwards.
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022
It could just be me but I've got a feeling there's two one each side. Noticed when I changed headlights. But I could be wrong might have just noticed an empty hole. Wasn't paying much attention to horns. |
| double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573
yes one each side, well they are on a 2007 Mark |
| Projectblue Member Since: 22 Nov 2011 Location: Devon Posts: 1098
I'd go with these: Ring twin air horn
The horns are essentially the same as 2 tone emergency 'dee daa' but it's only a single output compressor so you get a PWAARP. Remember that your alarm sounds the horn, so if you have a habit of accidentally setting your alarm off when leaving for work early, your neighbours may well begin to dislike you |
I thought so. Damn awkward to get to I think though. Wonder if it's only Puma's that have the two horns? Mine seems perfectly good no worse or better than to be expected. |
Where would you mount those? |
| d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044
I got a set of these on the 90, pretty decent sound and mounted nicely behind the grill, been on 3-4 yrs I guess with no problems. Recommended Dj 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
That's good to know. Are they louder that standard though? |
| T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101
twin horns on my 110...loud enough
They are a damn site louder than the old one was, no louder that the new 110 one but a bit 'harsher' maybe, I'll posts a pic when I get time DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
| Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514
I have one ahooga horn fixed on the left wing . I made a wiring for the horn with one relay and a Button/Switch on the dashboard . Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
