Home > Puma (Tdci) > Removing Side Windows
Bish
2002 Defender 90 Td5 XS CSW Java Black
I need to remove the side windows on my Defender. Can somebody please tell me the easiest way........are there hidden pop rivets??
Post #13246 22nd Jul 2009 4:53pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
A big sledge hammer Rolling with laughter Rolling with laughter
is the easiest way NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #13254 22nd Jul 2009 8:05pm
CapeLandy
South Africa
are these the rear sliding windows?
Just as a matter of interest, my one side kept getting jammed due to the felt guide getting all bunched up when trying to close it and the only way is to stick a sharp knife point to pull back the felt and keep it there while sliding the window closed again. Puma 110 - gone
Series III 1973 - going strong
Post #13256 22nd Jul 2009 8:31pm
Eduardo
CapeLandy, you are not the only one
I have the same problem with my sliding windows... and guess what?
Dealers was trying to solve it without too much sucess. Sad Sad My main problem is that my 2 boys travelled in the back and they use to open/close the sliding windows quite often, so the system is subject to a constant abuse.
I'm thinking to replace the felt with a U rubber channel to provide a better surface to slide the glass and keep it firm in the guide rail.
Regretably, not too much time to do it by myself Embarassed
Cheers Eduardo
Post #13264 22nd Jul 2009 10:28pm
TJ101
Re: Removing Side Windows
I asked the same question a while ago,,,,(To ease fitment of privacy tints) consensus of opinion was,,
Forget it !!! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #13266 22nd Jul 2009 10:44pm
Bish
This is so I can fit tints too! Oh well maybe I should just forget it.
Post #13275 23rd Jul 2009 7:00am
TJ101
They are easy enough to do, without removing the glass,, California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #13290 23rd Jul 2009 9:27am
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Where are you getting your tints from and what % have you opted for?
I'm looking for a little bit more security in the back and a bit more shade for the boy. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #13291 23rd Jul 2009 9:29am
Ninetenths
2007 Defender 110 Puma 2.4 XS CSW Java Black
This explains why the OE tints are smaller than the glass_ there is a small border of uncovered glass when they are applied, actually thinking about it I guess it prevents the tint lifting/being damaged as the windows are opened/closed- as you were! Pimped black '07 Puma
Equally Pimped Black Pick up Truck
Rollin deep
Post #13770 3rd Aug 2009 11:25am
AndrewS
Got mine tinted. They were done in situ no gaps. I went for a 70% tint (I think)
Post #13776 3rd Aug 2009 11:53am
