Home > Maintenance & Modifications > Fitting Roof Rack Spot Lights - Puma 110
Page 4 of 6 <123456>
BruceT
South Africa
Hi Paul,
Been batteling with this as I dont want to rip out all the wiring I have already done. Can I wire the switch up like this:
Pin 1 = 12V+ power in (on with parking lights)
Pin 2 = Switch illumination
Pin 3 = Earth
Pin 4 = Switched power out (to driving lights relay)
Pin 5 = 12V+ supply for telltale (from the driving lights when on)
Thank you.
Post #132759 20th Mar 2012 8:44am
PaulMc
BruceT wrote:
Hi Paul,
Pin 3 = Earth
Thank you.
Hi Bruce,
No, you can't wire the switch like that, for two reasons -
1: The Illumination and Tell-Tale are LEDs and will only work in one direction.
2: Pin-3 and Pin-4 are commoned.
However... Smile
You can easily modify the switch's internals to make it switch as you want Thumbs Up
This is what the switch looks like inside (bad photo alert Embarassed )
Here's a picture of the inside of the switch, which I've annotated with the terminal numbers and to show how the contacts connect accross pins 1 & 4 when in the ON position -
This is a close-up of the switch's circuit -
It's easy to convert this switch to a conventional live switching ON/OFF switch by cutting the brass track between the two holes, as marked in red in this next picture (I've use a Needle File to do this on the ones that I've modified) -
By cutting the track at this point, you separate pins 3 & 4
The revised circuit is now -
Pin 1 - Incoming Live from Main Beam/Dipped Beam/Side Lights (as applicable)
Pin 2 - Live from Dash Illumination
Pin 3 - Switch Earth (for indicator LEDs)
Pin 4 - Switched Live output to Terminal 86 of your Relay
Pin 5 - Live in from Pin 4 (for Orange 'tell-tale' LED)
You could link pins 4 & 5 inside the switch while you had it apart, by soldering a link across the brass tracks but I would just crimp an extra short length of cable into Pin 4 and loop it round into Pin 5 on the connector.
You will still need to use an accessory relay with a switch modified in this way but, at least it will be wired in a conventional manner.
Paul.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Paul.
Post #132762 20th Mar 2012 9:10am
BruceT
South Africa
Thanks Paul..
What do you mean by accessory relay? Is this the spot relay?
Post #132786 20th Mar 2012 10:49am
PaulMc
BruceT wrote:
Thanks Paul..
Yes, to terminal 86 of the spot lights relay. I've edited my earlier post.
. Paul.
Post #132788 20th Mar 2012 10:55am
BruceT
South Africa
Ah thank you. Let me try that. It would be easier than undoing the harness I made.
Will let you know how it goes.
Thanks again.
Post #132799 20th Mar 2012 11:40am
BruceT
South Africa
Paul I owe you many, many cold ones if you are ever in South Africa. Got it working and very chuffed. Thank you. Thumbs Up
Post #133301 22nd Mar 2012 5:38am
PaulMc
Bruce, I'm happy to help
Post #133338 22nd Mar 2012 9:36am
v40mav
Got all the lights done but used a standard rocker switch for one of the pairs as I didn't want to pay nearly £50 for the second genuine switch - previously under a tenner - !!
( Switches are YUG000540LNF - )
Anyone know of a supplier or source where these can be had at a sensible price - ? Defender 110 County SW
Disco 3 HSE
Freelander 2 HSE - SOLD going back to a car
www.lothian4x4response.org
Post #164762 27th Aug 2012 6:36pm
BruceT
South Africa
I cant remember where i ordered mine but they werent that expensive. Perhaps send Paul a PM and ask him as I bought my plug thingy s from him......
Post #164834 28th Aug 2012 5:59am
PaulMc
Unfortunately, YUG000540LNF, along with several other Defender and Discovery II switches, went up in price earlier this year, to 'silly-money' prices.
You will struggle to find anyone selling them at pre-increase prices (including those who had stock before they went up Mad )
If you're making your own roof lights loom, then the cheapest option for a factory fit switch is the Puma Heated seat switch YUF500150LNF
This switch is still around a fiver Thumbs Up
It uses the Black switch connector and, unlike YUG000540LNF, it switches the live and not the earth.
It is wired, as follows -
Pin 1 - Live in from fused supply
Pin 2 - Dash illumination
Pin 3 - Not used (but is internally connected to Pin 5 - Earth)
Pin 4 - Switched live out to accessory
Pin 5 - Earth
The 'heated seat' switch cap can be replaced with the blank cap from the blank that it's replacing on the facia.
This blank cap can be modified, with a 2.5mm hole, for the 'lense' for the Orange tell-tale LED to poke through.
You could engrave a suitable symbol onto the blank cap - this would allow it to illuminate with the dash lights.
Or, you could use a stick-on symbol from VWP or MUDSTUFF, which won't illuminate with the dash lights.
Post #164854 28th Aug 2012 8:03am
BruceT
South Africa
So I got mine just in time...... Thumbs Up Bow down
Post #164865 28th Aug 2012 11:14am
geobloke
Pin 5 - Earth
Know it is a while back. But blooming brill idea... Well done that man... :bow:
Post #200826 11th Jan 2013 2:04pm
I.AM_a driver
Scotland 2002 Defender 90 Td5 CSW Oslo Blue
yup, this thread will be invaluable when I come to wire up roof rack lights Bow down Mark S
CONVOY for HEROES
www.facebook.com/convoy4heroes
Td5 90
Thread in 'My Defender' Forum
Post #203643 20th Jan 2013 6:31pm
DiscoStu
United Kingdom 2013 Defender 110 Puma 2.2 SW Santorini Black
Can anyone tell me the best way through the bulkhead (on a Puma), from the engine bay to behind the dash. I'm wiring up 4 x lightforces, as shown below (fuses not shown):
I can't see a grommet to take it through, although I have found a smallish hole covered by a black sticker that a won't fit a grommet, although I may be able to enlarge it. I've got a Mud Pod for Carling On-Off-On switches to sit on top of the dash. Also, what's the best way to attach the wiring as it runs up the snorkel? My Disco 'best bits'
Defender 110 XS CSW 2013
Post #261173 25th Aug 2013 2:27pm
BruceT
South Africa
I pulled my wiring through a grommet behind the instrument cluster. (right hand drive)
To attach to the snorkel I used some zip ties.....not the prettiest option but doesn't look bad/hardly noticeable. "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
23MY Defender 110 D300 HSE X-Dynamic
https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA
Post #261314 26th Aug 2013 5:26am
