Home > My Defender > Mine now - 2003 TD5 90 HT
Page 7 of 24 <123 ... 678 ... 222324>
aaronmorris
Looking good mate
Post #130636 11th Mar 2012 10:33pm
RRUK
Removed the rear lights to find them bunged up with mud. Scraped it all out and used the air line to blow out the debris. The new compressor is already coming into its own. 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #130656 11th Mar 2012 11:44pm
RRUK
All the underneath now pressure washed and dried and will be ready to start painting the chassis hopefully at the weekend, after that, the Waxoyl treatment inside and out.
The thing is, I might do the suspension at the same time, taking it slowly, 2 corners off per time and then I have more access to paint properly. 2016 D4 HSE
Post #130801 12th Mar 2012 7:09pm
RRUK
Finally replaced the suspension components
Had a clear weekend to work on the suspension, weather not great but luckily I have a double garage to work under.
The aim of this work was to improve the Defender's road manners, with the current off road specification of a 2" lift it was quite scary on the road on anything other than a flat piece of motorway. Hit a bump and the car would jolt off it, speed was hampered and it felt most comfortable and safe at 50mph -which I didn't exactly feel was much of an improvement over my Series 3 from when I was 17 Sad I think the shocks on it were also mainly to blame, as it had a mix of Pro Comps and one De Carbon on the rear, when I got those off and tried to flex them the rebound was almost non existent. So, maybe they were to blame more than the springs.
Anyway, with every known tool to man ready to hand including the recently purchased Aldi air compressor and tools (plus a few more from Machine Mart) I set about it...How hard can it be right? Shocked
Started with the Rear OS, all went rather well, I took my time, the only problem being that someone fitted rear dislocation cones which made getting the spring out a faff, luckily I'd had the forethought to buy a set of spring compressors from Screwfix just in case. Without these, I couldn't have done any of them.
The new spring and shock went in fine: Very Happy
The rear NS was a complete B Evil or Very Mad tch! The top shock mount had 'collared' slightly and so the bushes wouldn't go on. I got the first done, and had to sleep on the second after trying for 4 hours. I was going to slice the bush to help it expand but in the end I used my angle grinder with a very light sanding pad (P180) and just cleaned up the end of the mount, with a little bit of grease the bush went on ok.
The front Shocks were a bit of a pain, the lower shock mounting bolt is very hard to get at and you have to grip the shock body through the spring to try and remove the bolt. I got tired of this so I used an air sabre saw and sliced through it instead as I was throwing them away anyway. I had to use 2 jacks to manipulate the axles up and down, but even with no support the axle wouldn't drop low enough for the springs to simply fall out, that's the problem with extra big springs. The compressors earnt their keep that's for sure.
Getting the shock out of the turret is also a nightmare, so I just put a cutting disc on the angle grinder and did it the easy way. I did this for both sides and saved loads of time. I didn't replace the turrets, saw no point, its just more expense and there's nothing wrong with these.
Here you can see the final front going together.
Here you can see the difference between the old Bearmach Blue lift springs and my standard HD springs. Many thanks to fellow forum member Steve B for the springs.
I love the look of fresh parts fitted Cool
Old stuff going to the skip: Good riddance - why anyone would want to do that to their LR is beyond me, it was awful.
The finished article:
Not sure if you can tell immediately without me putting a pic below of the before look, but it sits quite a bit lower and preliminary test drives show massively improved road manners, and it now sits at 60mph easily, so a 10mph increase from before. (before you jump in and tell me that it should go faster than that and there must be something wrong with it, 60mph is NOT the top speed, just where it all feels smooth and right.)
And before the work:
Tools Used:
Trolley Jack
Bottle Jack
LR Front jack
Axle stands - never needed and too short to support the chassis by about a foot Shocked
Spanners
Impact socket and Impact wrench
Air compressor
Air sabre saw
Angle grinder
Pry bar
Hammer
Spring compressors
Grease
Air socket wrench
Screwdriver
An article in LRO said it took a mechanic 20 mins per corner to do this on a Range Rover Classic (same setup). I can't see how that's possible, on average each corner took me 2hrs. I don't mind, I did a thorough job, copper greased everything made sure it was all correct, and that's all that matters to me. I saved myself a few hundred quid maybe on garage rates and have learnt more about the car.
Still waiting for my mate to be available to help me install the La Salle headlining Big Cry
Still need to paint and waxoyl the chassis. Rolling Eyes 2016 D4 HSE
Post #132489 19th Mar 2012 11:01am
mymini007
1986 Defender 90 200 Tdi HT Java Black
Looks much better now its at the correct height. You cant polish a turd!
But you can roll it in glitter Smile
2006 Mercedes Benz CDI320
2001 Volkswagon Caddy Van 1.9 SDi
1993 Nissan Patrol 4.2 TD
1986 90 200tdi - SOLD
1990 Mini mayfair (highly modified) - FOR SALE
Post #132490 19th Mar 2012 11:29am
SteveT247
England 2002 Defender 90 Td5 XS CSW Bonatti Grey
Looking good mate Thumbs Up
Post #132493 19th Mar 2012 11:38am
Looks good, I'm sure it drives even better Cool QRZ 2e0vpf
Post #132532 19th Mar 2012 1:56pm
Looks like you need a winch to make best use of those front HD springs, but otherwise much better compared to the 'before' shot. Darren
Post #132535 19th Mar 2012 1:59pm
RRUK
Nah, never required one, not planning on going winching either. 2016 D4 HSE
Post #132541 19th Mar 2012 2:12pm
RRUK
Getting a few things done before the Convoy4Heroes run on Sunday.
Oddly (for me) I gave the LR its first full wash today since I bought it, now I can see how much effort I need to put into the paintwork with the Porter Cable DA polisher etc. Might do that tomorrow as it's a bank holiday.
Also, I bought a window tint for the rear safari door glass and did that myself, only cost me £5.69 and was surprisingly easy to do. The end result looks really good.
Apologies for the rubbish photo quality, these were taken on my iPhone 3GS.
 2016 D4 HSE
Post #137149 5th Apr 2012 1:26pm
Window tinting is a no brainer, keeps prying eyes out, I even did the garage windows!!!
Looking great!!!! QRZ 2e0vpf
Post #137151 5th Apr 2012 1:40pm
RRUK
Decided to go over the paintwork with the 3 stage process (Paint clean, Paint Polish, Wax) and it is much improved, the next time I do it I'll need to clay bar the car all over but for now this will do.
Still need to do that blasted headlining! Big Cry
 2016 D4 HSE
Post #137221 5th Apr 2012 6:23pm
chiefstoker
England 2005 Defender 90 Td5 HT Zambezi Silver
I really shaping up nicely now RRUK Cool nice to see another tidy HT 90 Thumbs Up 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy
Post #137263 5th Apr 2012 8:44pm
proper job Thumbs Up great transformation
Post #137268 5th Apr 2012 8:48pm
RRUK
Thanks Chaps. Very Happy 2016 D4 HSE
Post #137277 5th Apr 2012 9:10pm
