Home > Technical > Visco fan in high altitude
AlpenAndes
Austria 2010 Defender 110 Puma 2.4 SW Belize Green
Does anyone have experiences what the visco fan does in high altitudes?
Mine kicks in permanently in about 2500m. That costs power and makes also this horrible noise. Have listened to other TD4s which did not make the same, but did not have the chance to find out if they start to do a similar thing maybe higher up still. I can imagine that it might kick in permanently in high altitude due to the change in pressure, the question is just when, as 2500m shall not be something extraordinary. I guess...
According to the clueless dealer it is like that.
Post #131762 16th Mar 2012 7:51am
IMHO: altitude should not make any difference, the fans speed is dictated by the viscosity of the oil in the viscous unit and the temperature.
Post #131765 16th Mar 2012 8:38am
mudrut
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Echo what the BP-meister says.
I regularly use my vehicle at around 2600m (accompanied by customers in their 2.4 TDCi vehicles) and have not noticed any noise from theirs or mine.
Is your vehicle and air-con model? Also, does it make a difference what the external temperature is? Finally, did you notice any fluctuation of the temperature gauge from the norm?
regards
Ian
Post #131784 16th Mar 2012 10:05am
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
I've done 10,000ft in my tdci and did not run with the fan constanly on. Confused
Post #131788 16th Mar 2012 10:16am
AlpenAndes
Thanks for the replies so far.
The car got AC, but it does not matter if that is on or off, the fan keeps on turning. I anyway switch the AC rather off. I did not notice a change in the temperature gauge and we are talking about temperatures above 10°C where I noticed it. At least I do not remember right now what it did in winter time when it was below zero.
Then I will keep on discussing with the dealer. Although that may mean they will have to an extensive test drive.
Post #131836 16th Mar 2012 2:09pm
Eduardo
AlpenAndes,
In same conditions in Paso Libertadores (3.000 mts), Los Andes (3,500 mts), Valle nevado (3,000 mts) and El Yeso (2,700 mts) I didnt remember that the fan was working all the time.
Cheers Eduardo
Post #131842 16th Mar 2012 2:39pm
wslr
There is a barometric sensor in the Powertrain ECU, but this tends to make changes to the way the turbocharger operates.
Post #131887 16th Mar 2012 6:19pm
the viscous unit may be faulty, try changing the fan unit
Post #131895 16th Mar 2012 6:39pm
ericvv
you can test it. when the engine is cold and not running, contact off, try to move the fan with your hand. if it runs freely all is ok, if it does not, it is faulty.
by the way a viscous fan always turns when the engine is on, never sits still, albeit does not turn at full speed if it is not necessary. when driving in the mountains, my personal experience is that the engine needs to work harder, and fan more often than on flat surfaces will keep turning at higher speeds in order to cool everything down. You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #132311 18th Mar 2012 3:34pm
AlpenAndes
Thanks ericvv, will check that next time if the fan moves freely.
Guess that also cost some hp of the anyway few the thing carries originally.
Eduardo, all this nice places with the fan running as well when crossing Paso Sico 4100, San Francisco 4700, Agua Negra in 4700m this summer before the Bolivian Winter. Had to leave Paso Pircas Negras for another year, Carabineros said it is not recommended after the rain started and saw on Ruta 40 what it means when the rain in the Andes washes away a road.
Saludos
Oskar
Post #132439 18th Mar 2012 11:53pm
MK
Probably at those altitudes you need to push the gas pedal more than usual which makes the engine hotter and you can not be see any change on the temp gauge. Over 95° or do I can hear the fan spinning. Puma 110" SW
Post #132441 19th Mar 2012 12:12am
