![]() | Home > Td5 > EGR blanking? |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5942 ![]() ![]() |
Take acoustic cover off engine,
If there is a big sticky out bit with little pipes going to it, on the inlet manifold, where intercooler hose attaches, you still have one. Easy job to remove ![]() Andy |
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 655 ![]() ![]() ![]() |
What it looks like depends on the age of vehicle. As an 03 yours should have the later type with two pneumatic actuators on - earlier ones only had the one. Yours should therefore be blanked in the same way as the instructions above.
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 610 ![]() ![]() |
Here's our Td5 EGR blanking kits - http://www.alivetuning.com/EGR_Bypass.html
You will need an EU3 kit, as you will have the EGR cooler at the front of your engine. Our EGR kit fitting instructions are available to download here: http://www.alivetuning.com/docs/EGR%20bypass%20kit.pdf Regards, Gary. |
glyn.c Member Since: 30 Oct 2011 Location: east devon Posts: 33 ![]() ![]() |
can only comment on alive's kit ,just download the idiots guide off their site and its so simple even i can do it ![]() GLYN |
chiefstoker Member Since: 11 Oct 2010 Location: Weston-super-Mud Posts: 897 ![]() ![]() ![]() |
The biggest problem is actually removing the EGR with seized in bolts, good luck
![]() Beer 'n Sex 'n Chips 'n Gravy ![]() |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2028 ![]() ![]() |
Has already been De-cat'd, already got K&N filter, already got silicone hoses. I'd be surprised if the EGR isn't done. Will take a look over the weekend. 2016 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
Peter Member Since: 04 Mar 2012 Location: Kent Posts: 153 ![]() ![]() ![]() |
Okay this may be a dumb question but if you de-cat a late td5 and remove EGR will this make the vehicle fail the new 2012 MOT rules that come into force in April ?
(Source: http://uk.autoblog.com/2012/01/04/changes-...eady/)[/i] Also mentioned here about post 1992 vehicles de-catted: http://www.pistonheads.com/gassing/topic.asp?t=1029872 |
No Peter, not at this stage 'spark ignition engines' only
![]() This was interesting though on the Pistonheads thread: rds1210 said: just took the car for mot i checked it over three weeks ago give the underneath a thin coat of waxoyl the vehicle passed the mot but the mot fellow said if the underneath is like that next year he will refuse to mot it Can he do this I only sprayed a thin coat three weeks ago and because of the weather it as not dry out yet HAVE OTHERS HAD THIS PROBLEM before He could have refused to MOT it this year if he thinks it's dirty enough and nothing to do with any changes in January, take it elsewhere next year. 2005 TD5 90 Hard Top Beer 'n Sex 'n Chips 'n Gravy ![]() |
I think its the Waxing issue, MOT'ers tend to dislike the wet stuff or its laid on too thick.
Same goes its its covered in heavy mud I believe. |
Checked mine and it's not been EGR'd yet.
Something for the future. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2669 ![]() ![]() ![]() |
Do it, and while you're at it, remove the cat and centre silencer box ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
They are already done. People say its an improvement, but what exactly do you notice? 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
When I removed the centre silencer on my D2 Td5, I noticed much quicker turbo spool-up, faster acceleration, and a slight reduction in fuel consumption. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
