Home > Maintenance & Modifications > Varying results with headlight upgrades
Page 2 of 2 <12
Trouble is the the LED one's is I don't doubt that they're good. bloomin heck they should be for the price! But With such a value to them and only taking a few mins to remove they'd seem a good target to me for theft. Shocked
Post #131619 15th Mar 2012 6:06pm
BigMike
Can I just make a plea for people NOT to install HID? They WILL dazzle people coming the other way which is a massive problem if you're on a motorcycle. If means you can't see the road surface in front of you so whereas a car can easily go over a slippery manhole cover on a corner, in the dark with headlamp dazzle in that situation a bike is highly likely to crash. So PLEASE do not covert your LR to HID.
Bulb replacement is extremely effective and already covered in this thread. I cannot understand the utter obsession that Land Rover owners have for wanting to light up the scenery like they're in a Bond movie. It's bloody ridiculous and dangerous.
Post #131627 15th Mar 2012 7:29pm
leeds
The good old light debate!
There are literally hundreds of light emitting devices available for use with Defenders be it LED work lights HID headlamps etc etc.
What amazes me is that so many of the lights available do not give the basic bit of information which is essential for lights and that is the actual light output from the device.
The power consumed by the unit be it 6/21/5/75/100 watts IS important for working out cabling/fuse/relay size but has no direct relevance to actual light output or range.
Lightforce lights and the J W Speaker lights are a couple of manufacturers who do give a measurement of light output.
When lumens are mentioned are the manufacturers talking raw or effective lumens? Candela or candlepower.
I for one will be happier when all light manufacturers gives out realistic effective lumen figures. and on an acceptable industry standard
Then there is the IP rating or Ingress Protection rating for dust and water. A lot of the work lights etc do not have an IP rating, how often have you seen lights more akin to goldfish bowls?
As for the Defender light switch issue on our recent trip we picked up a couple of these Have not had a chance to play with them yet
Brendan
Post #131641 15th Mar 2012 7:45pm
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
Brendan
That looks great. If I understand the translation of the website correctly, it is also available with wiring for auxiliary lamps. Would that allow auxiliary lights to be wired so they come on with main beams?
I look forward to seeing how you get on with this.
Post #131652 15th Mar 2012 8:12pm
mudrut
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Mein Deutsch ist nicht so gut, aber ich benutze diese.......
ARB Headlight Upgrade Loom
Ian
Post #131655 15th Mar 2012 8:18pm
Has anyone ever tried a 130w spot?
Post #131663 15th Mar 2012 8:31pm
SGH
I had on a previous LR 90 IPF 170/100watt Headlamp conversion kit.....
HIGH BEAM
HIGH BEAM WITH LIGHTFORCE LIGHTS ON
 993 Varioram - Guards Red
Defender 2.5 300TDI 110 HCP - Keswick Green
Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE
Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE
Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE
Post #131673 15th Mar 2012 8:52pm
MK
Probably a 4000K HID is a good choice. White enough and long lasting bulbs. Uprated H4 bulbs (Philips, Osram, PIAA, etc) have very limited life. IMHO Puma 110" SW
Post #131707 15th Mar 2012 9:43pm
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
mudrut wrote:
Oh yes, LED Lightbars are oh so lovely! SteveS off here had his on the Arctic Trip last month. When he was several hundred yards behind and sparked it up, it was so bright it was deafening (if you know what I mean.)
I was thinking about those LED headlamps. As the MOT regs make retro-fit HID a non-starter on a Defender from this year, the next best in terms of price performance is a new loom, better lenses and high wattage bulbs. I reckon that is still a £350 solution fitted.
I have ample auxilliary lighting on my trucks, but sometimes you just want a well-patterned, bright dipped beam.
I wonder how long before LED replacements are £500 a pair?
regards
Ian
I seem to remember somebody said "god-like" when I lit up crossing the Arctic Circle Very Happy
Post #131730 15th Mar 2012 10:11pm
Uprated H4 bulbs (Philips, Osram, PIAA, etc) have very limited life. IMHO[/quote]
True, But I don't drive at night very much so it doesn't worry me too much. Thumbs Up
Post #131741 15th Mar 2012 10:41pm
Page 2 of 2 <12
