Home > Maintenance & Modifications > Varying results with headlight upgrades
mudrut
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
I was catching up on reading on the forum and a common theme seemed to be headlight upgrades and the woes of the melting light switch. Smile
I have tried a fair few different solutions and some still populate my vehicles. I thought I would share them here and then ask if there are others that you guys have tried and like.
Firstly, there is the simple bulb upgrade. I am always suspicious of the claims like "Ten times brighter than the sun and still only consumes 55W". However, I have found that the PIAA Extremes give a noticeably brighter light whilst staying within the limits of the standard power consumption. I have run them since 2005 and never melted a lightswitch. I tried the Halfords and Philips offerings and again, noticed an improvement, but found it was worth spending the extra on the PIAA.
Without a doubt, the brightest light (or should I say whitest?) has come from an HID conversion. I am talking about the plug and play type where the HID bulb is in an H4 format so fits in the existing lenses. I say 'fits'. I was given one kit to play with and found that I had to dremel the metal on the back of the lens slightly to make the new bulbs fit. I found that the light was pleasingly bright, but because the bulb didn't sit in the optimum part of the lens, the beam pattern was uneven and quite sparse. A year ago, I bought a double cab with a better quality HID conversion already in it and that has a good beam pattern combined with superior brightness. The only thing I have found with aftermarket conversions is that in heavy off-road usage, sometimes a bulb goes out. Also, if a component fails, it is not as simple to replace as a normal H4 filament.
Probably my favourite solution thus far has been the IPF upgraded headlight lens with 100W bulbs (you can use up to 145W!) and a wiring loom. Bomb proof and bright with a very useable beam pattern.
I have yet to play with an LED solution.
What say you all?
regards
Ian
Post #131557 15th Mar 2012 3:01pm
Hi Ian,
I have upgraded myself to Phillips extreme. BPman on here has PIAA's also like yourself and he compared them the the Phillips extreme bulbs. He mentioned that the PIAA's light output was slightly better. However at £60 and the Philips being much less cost (roughly£20) the difference is very little little. I also have combined two Roolites which are 100w each and at the same time I fitted Wipac Crystal headlight units too. Well and SS rings. Thumbs Up
Post #131570 15th Mar 2012 3:36pm
mudrut
Are Roo Lites the copies of the LightForce?
I have the Wipac Crystals on the 90 and they perform well, but will probably replace them with IPF and a loom when they break. I have found that the IPFs seal a lot better against water ingress than any other unit.
regards
Ian
Post #131575 15th Mar 2012 3:43pm
The problem with this sort of thing is that it's always very subjective. Most people don't have experience of a wide variety of options and even if they do, it's usually over a long-ish period of time rather than a proper side-by-side comparison. People also have different opinions of what acceptable, or what represents value for money. It's the same story with things like tyres, too.
Personally, I was very happy with the Philips bulbs that I fitted to my old Discovery and Freelander (Vision Plus and X-treme Power respectively). I now have a set of the latest incarnation and, based on positive reviews here, a pair of Wipac Crystal headlights ready to fit to my 110 when I get a minute.
Performance aside though, value for money plays a big part, too. There are guys on here that have the latest LED headlights and rave about them. However, at around £1k a pair, they're more than ten times the price of the set-up that I've settled on. For me, I can't imagine them performing ten times better, so they don't represent value for money when an adequately significant upgrade is available for much less, but I expect those that have paid for them think otherwise.
What's really needed is an objective comparison of a variety of bulb and headlight combinations with proper measurements of light output and beam pattern. It's the sort of thing that you might expect a magazine to take on but comparison tests these days seem afraid to reach a conclusion for fear of upsetting advertisers Rolling Eyes Darren
Post #131577 15th Mar 2012 3:49pm
I have found Roolite's to be basically identical to the Lightforce units. From what I can gather Roo's are an Austrailian make and Lightforce is UK / Europe maybe even US. Not sure on that one. Either way I like them. They used to be cheaper around £50 each plus VAT but now more along the lines of £70 - each. Quite interested however in other units that have 130w output however I think a lot of them have glass lenses and that I really don't want.
Regards,
Steve
Post #131580 15th Mar 2012 3:52pm
I was thinking of a doing a picture comparision myself compared to original bulbs however I was pressed fro time when fitting and the weather wasn't to good so I didn't get the chance at the end of it. Sad
Post #131582 15th Mar 2012 3:54pm
mudrut
I suppose we are drifting off topic now we are onto auxiliary lights, but Lightforce are Australian.
From what I can find from a quick search, Roo Lites appear to be a Taiwanese copy. Seems there is a whole 'Roo Lites vs Lightforce' debate going on the various Australian forums. Smile
regards
Ian
Post #131589 15th Mar 2012 4:13pm
I did exactly that when I fitted the Philips bulbs to my Freelander.
Before:
After:
It gave an indication that the new bulbs were brighter, but I wouldn't claim it was scientific. It also only shows the relative improvement over the old standard bulbs. What's really needed is something that shows the relative merits of the upgrade options. Darren
Post #131593 15th Mar 2012 4:43pm
dgardel
Italy
JW Speaker LED
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #131601 15th Mar 2012 5:17pm
regards
Ian
I didn't know that. Laughing I don't think there is any real difference really. Except of course 240's which are bigger by Light Force. As you say slightly off topic. Thumbs Up
Post #131606 15th Mar 2012 5:31pm
Still off topic
Main beam:
42" LED lightbar
Post #131608 15th Mar 2012 5:40pm
Wipac Crystal, Phillips Extreme +100% bulbs & stainless bezel:
Post #131612 15th Mar 2012 5:48pm
mudrut
Oh yes, LED Lightbars are oh so lovely! SteveS off here had his on the Arctic Trip last month. When he was several hundred yards behind and sparked it up, it was so bright it was deafening (if you know what I mean.)
I was thinking about those LED headlamps. As the MOT regs make retro-fit HID a non-starter on a Defender from this year, the next best in terms of price performance is a new loom, better lenses and high wattage bulbs. I reckon that is still a £350 solution fitted.
I have ample auxilliary lighting on my trucks, but sometimes you just want a well-patterned, bright dipped beam.
I wonder how long before LED replacements are £500 a pair?
regards
Ian
Post #131614 15th Mar 2012 5:51pm
regards
Ian
I thought anything over 55/60 wasn't road legal though? All after market bulbs I've seen for sale online at 100w ect have been not road legal and for off road / rally use only. Confused
Post #131616 15th Mar 2012 5:53pm
mudrut
Agreed. How do they stand with the LED ones above? In terms of light output, they must look like all hell breaking loose. Twisted Evil
regards
Ian
Post #131617 15th Mar 2012 5:57pm
