![]() | Home > Maintenance & Modifications > Stereo help please... |
Sounds flippant I know but why not just slip it out and have a look? From memory they are flat but I can't be 100%.
haworthj Member Since: 01 Nov 2010 Location: Sussex Posts: 178 ![]() ![]() |
I haven't because I don't have the right tools - and my local Halfords haven't got any. Is there something I can make up to slip it out?
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20967 ![]() ![]() |
I wouldn't try a home made way of getting it out been there tried that and failed! Ebay would be good and cheap. you just need a two pronged realease keys. should be very cheap. For memory pins are flat ![]() |
Thanks Mike. I'll have a rummage around Mrs. H's wardrobe this evening.
hi haworthj
I had a standard LR (with jack) radio/cd and replaced with CD, nothing required - straight swap the only thing you have to do is remove little metal flanges on the left and right of the standard radio/cd apature / hole... you'll see what I mean when you take the radio out make sure you flash the unit... I have my leads all routed through to the dash-top glove box ... no drilling required. Asteroids - they take a little while to master but are great units ![]() ![]() Click image to enlarge |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
The stereo plug on all the Defender are ISO (International Organisation for Standardization). This means it falls in line with all main car stereo manufacturers.
You will find that all major car stereo companies' products will plug straight in. Glyn ![]() ![]() |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 ![]() ![]() ![]() |
Sometimes the +12 accessory and +12v Perm lines are swapped... You'll soon know when you turn the radio off.. ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
If that's the case, what colour wires will I have to swap over?
Cheers James |
That looks very smart. |
I too have an Asteroid. 'Plug and play' no wires to swap whatsoever. http://www.defender2.net/forum/topic7481.html?highlight=asteroid If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Not sure what the wire colours will be, but they are A4 and A7 on the plug... ![]() [/img] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
Thanks for all your help gents. That's why I love this forum. It arrives tomorrow. Fitting over the weekend.
Cheers James |
Good luck ![]() ![]() |
