Home > Td5 > Rear crossmember re paint
ibexman
My 2006 90 cross member needs refinishing , i was thinking etch primer and satin black hammerite/ chassis paint of some sort Any suggestions Thumbs Up
Post #131025 13th Mar 2012 5:51pm
mymini007
1986 Defender 90 200 Tdi HT Java Black
I used etch primer and halfords satin blaack You cant polish a turd!
But you can roll it in glitter Smile
2006 Mercedes Benz CDI320
2001 Volkswagon Caddy Van 1.9 SDi
1993 Nissan Patrol 4.2 TD
1986 90 200tdi - SOLD
1990 Mini mayfair (highly modified) - FOR SALE
Post #131026 13th Mar 2012 5:52pm
Zagato
Etch primer is pricey stuff necessary for aluminium etc. An ordinary cheaper primer can be put on the steel rear cross-member IF it needs it, you can usually just paint over if the old paint is good with no rust etc Thumbs Up
Spraying is definitely the way to go on this, brush strokes can just look a right mess if not done properly even on working vehicles, may as well do it right in the first place, can ruin it otherwise Rolling Eyes
Post #131028 13th Mar 2012 6:09pm
Killer90
Site Sponsor
yer as zag said you only need to prime bare metal or rust repairs if the crossmember is good well should be on a td5 06 give it a light scotch/ key really fine and spray it black simples Thumbs Up im guessing its just faded as my 90 was when i got it paint was flakey were someone bojed it up last time so i stripped it back to bare metal and had it sprayed out of a gun Mr. Green
Post #131030 13th Mar 2012 6:22pm
Zagato
I tried to do mine with POR-15 (The UV resistant type!) with a brush and made a real pigs ear of it as it's thick stuff, so I took it off before it dried. It can't be that much to get it sprayed professionally if you were really conscious of appearance £50 maybe (was quoted £70 to do a rear door so should be about right). How much is it for two cans £20-30 maybe so not much more!
Post #131036 13th Mar 2012 6:30pm
Killer90
Site Sponsor
go to b&q paint in a spray can called plasticote they do a paint for metal in gloss satin or matt black about £5-£7 a tin one of them would do a whole crossmember easy Thumbs Up
Post #131044 13th Mar 2012 6:50pm
Zagato
Plasticote is good stuff, sprays on nicely, Thumbs Up Ive been buying it at Halfrauds Thud
Post #131048 13th Mar 2012 7:06pm
jerseyman
Another vote for Plastikote. I am not an enthusiast of Hammerite smooth, it seems a bit brittle to me.
Post #131050 13th Mar 2012 7:43pm
Killer90
Site Sponsor
Laughing how much is it there zag Question
Post #131051 13th Mar 2012 7:43pm
Zagato
I think it was about £12. Will check out Homebase, B&Q is further away from me Sad Aldi miles away Big Cry
Post #131059 13th Mar 2012 7:58pm
Killer90
Site Sponsor
B&Q are the cheapest aswell always the way Laughing
Post #131072 13th Mar 2012 8:24pm
alanhid
Scotland 2006 Defender 90 Td5 XS CSW Bonatti Grey
Re: Rear crossmember re paint
Exactly what I'm thinking of doing with my 2006 90 Thumbs Up I was going to use the hammerite paint as it states no primer required........satin black? Life is not a rehearsal!
Def 90td5 CSW xs 2006
Post #131077 13th Mar 2012 8:27pm
Killer90
Site Sponsor
hammerite spray is horrible dont do it mate Big Cry it is like spraying on vinegar its really tacky when applying coats stick with plasticote or holts Thumbs Up
Post #131088 13th Mar 2012 9:05pm
amondeggs
United Kingdom 1999 Defender 90 Td5 HT Woodcote Green
If you do use Hammerite then be careful in the future what you spray on top of it. It does react badly with other paints and you end up with coracle glaze effect.
I stripped to bare metal, then acid etch primer followed by normal primer, rub back with wet and dry and then top coat of satin black. Thumbs Up
Post #131089 13th Mar 2012 9:06pm
jst
any black tractor paint or Halfords satin black have worked very well on mine in the past. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #131111 13th Mar 2012 9:34pm
