![]() | Home > Maintenance & Modifications > Which Bumperettes? |
iruffell Member Since: 03 Sep 2010 Location: Marlow, Buckinghamshire Posts: 343 ![]() ![]() ![]() |
I'm going to fit some bumperettes so that next time I reverse into a Clio I only damage the Clio
![]() I'm thinking of getting the Terrafirma ones as they will sort of match the tubular XS side step ![]() Any thoughts? |
No thoughts of my own but I have chosen a few choice thoughts from others..... http://www.defender2.net/forum/topic6033.h...umperettes http://www.defender2.net/forum/topic10875....umperettes http://www.defender2.net/forum/topic9077.h...umperettes http://www.defender2.net/forum/topic8899.h...umperettes http://www.defender2.net/forum/topic4422.h...umperettes http://www.defender2.net/forum/topic1525.h...umperettes http://www.defender2.net/forum/topic4273.h...umperettes If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Very pleased with my Safari Equip ones...
http://www.safari-equip.co.uk/index.php?page=64 Much nicer than the ebay cheapies, but without blowing the budget. Galvanised & painted, looks great, comes with stainless screws. No drilling, 10 mins to fit. ![]() Came from Brendan (aka "leeds") at 4x4 Overlander (a sponsor of the forum) - Brendan was a couple of quid cheaper than Safari Equip direct, and they were here within 48 hours ![]() I "tested" them when I reversed into a low-down sign ![]() ![]() Handy to stand-up on to wash the roof of the Defender as well ![]() |
They don't show up on their website, do they still sell them? |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
Nothing shows up on Brendans website
![]() If he hasn't got them you can order them directly from Safari Equip, nice bloke to chat to and deal with also ![]() ![]() Last edited by Zagato on 12th Mar 2012 4:35pm. Edited 1 time in total |
Yes we do still sell them.
Our website is like a Defender an ongoing project! Not made any easier with internet problems. Currently using a 3G dongle as have had 3 routers in last 2 months!. Let me know if 90, 90 with mud flaps or 110. The Safari Equip ones work with their swing away wheel carriers. Please note that not all after market bumperettes work with wheel carriers as some are too close to rear cross member/use same bolt holes as carriers. Safari Equip ones are 6 mm steel, galvanised and then powder coated. Brendan |
Thanks Brendan, what the cost of a set for 110 incl shipping? |
The SE ones are very robust and a great bit of kit - slight word of caution though. They are galved then sprayed, not acid washed or blasted after the galv so if you get a pressure washer near them (like my LR dealer did) the paint will fly off faster than a hookers knickers. If I bought them again I'd buy a set without the chequer plate tops on and unpained, get them blasted then powder coated then rivet on the chequer tops.
Mine have been OK under the pressure washer, had them a year
Not sure they're powder coated? I thought they were sprayed
Apologies, yes sprayed
Powder coated
Powder coating sticks to mild steel better then to galv. It also prefers nicely rounded edges to square edges. I can show examples of powder coating on bare mild steel peeling off from square cut edges (not SE gear) Powder coating on bare mild steel gives a smoother finish then on galv which has more of an orange peel finish. It is swings and roundabouts, but if powder coating does come off they will not rust. Cost for 110 is £153 plus £12 carriage if required. 90's are slightly cheaper Brendan |
Deleted, sorry double post, blasted internet!
Brendan Last edited by leeds on 12th Mar 2012 9:01pm. Edited 1 time in total |
Aesthetically it doesn't look great when the coating comes off in sheets though, despite not rusting. Powder coating does not stick at all well unless the surface is either blasted or significantly roughed up or etched in some way.
