Home > Puma (Tdci) > How long will it weep for?
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
OK, the inevitable has happened, the Puma's vacuum pump has a very minor weep on the engine side at the base. Big Cry
So does anyone have any idea how long I might get out of this?
I've got a replacement ordered for Monday at the dealers in Sydney, but I have about 400 - 500km of driving to get there.
I'm towing about 1.5t of trailer as well and there's a lot of hills to get over. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #13048 17th Jul 2009 8:29am
Grockle
Derek snap!,ours went yestwerday,in the dealers now,had to show them dullbirds thread for the correct part no.!,the conditions your driving in keep checking on it as it will start to through oil all over the engine bay,good luck, how's the trip going otherwise? part needs to be LR012183 this is the latest replacement pump. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #13051 17th Jul 2009 9:37am
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
You should get quite a while. Basically it is weeping engine oil so you've got several litres to get through Wink
Mine was spraying quite a bit around the engine bay but even so, the total amount of oil was probably only 50ml.
I drove a few hundred miles on it without any issues. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #13052 17th Jul 2009 10:00am
Fontuin
2008 Defender 110 Puma 2.4 SW Zambezi Silver
I drove mine a few thousand km from when it started leaking until it was replaced with no problems other than an oily engine bay and my brakes did start feeling a little "hard" towards the end. I didn't even have to replace any oil in that time.
It doesn't leak all the time when the seal goes and I did in fact never see it leaking, only the evidence there of.
Post #13053 17th Jul 2009 10:31am
dm_td5
Thanks, that's comforting information.
Grockle it's going in to the same dealers as dullbird's did so they know all about the correct part I hope. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #13060 17th Jul 2009 2:22pm
dgardel
Italy
After the initial leak, I drove for 1500km ...
No problem......
Post #13064 17th Jul 2009 6:33pm
mse
i did 700 ish miles on it Mike
Post #13065 17th Jul 2009 7:00pm
YORKSHIRELAD
Hi lads. Bearing in mind that I still have the original pump, and that I will inevitably need a replacement in the future, can I ask you all how many miles or Km's you had clocked up before it failed?. I don't do much mileage and although this might sound strange, I would really like it to fail whilst it's still under warranty. If I squirt oil under the bonnet, do you think I could con them into a replacement Smile . Thanks,
Richard 1963 Series 2A truck cab
2008 110 SW
Post #13067 17th Jul 2009 8:08pm
mse
About 6 or 7k i think Mike
Post #13068 17th Jul 2009 10:05pm
alantd
10k miles.
I considered doing the same thing Wink
I don't think they could really tell (if you use a fine enough spray Mr. Green ). The guy took one look at mine, ran his finger through the oil. proclaimed that it was definitely engine oil and certified the replacement. One that started out as a 2.4 TDCi 110 XS
Post #13069 17th Jul 2009 10:24pm
YORKSHIRELAD
Thanks. I should be o.k until next year then.. Very Happy .
2008 110 SW
Post #13070 17th Jul 2009 10:26pm
Eduardo
Quite strange,
First one failed at 12,000 miles; second one (1st type) still working OK after 25,000 miles
Something should be wrong.... Sad Sad
Cheers Eduardo
Post #13071 17th Jul 2009 11:21pm
mrwoo
United Kingdom 2004 Defender 90 Td5 CSW Epsom Green
Ive done 38k and still on the original pump, May 07 Defender
Post #13076 18th Jul 2009 3:40pm
Grockle
road tested 3 miles all ok, told LR, can't belive it's still oil tight,will keep you posted. 2.4 90 XS
Post #13080 18th Jul 2009 10:00pm
dm_td5
Well it hasn't got any worse for me and it is going in for a replacemnet tomorrow morning. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #13084 19th Jul 2009 8:31am
