![]() | Home > Maintenance & Modifications > Duralac instructions please |
My tube of Duralac jointing compound arrived without instructions - no luck on the internet so far.
Since certain members ![]() Specifically, I'm screwing steel bolts (KuRosted) into aluminium rivnuts. Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Google Schmoogle states it's ready to use.....
http://www.llewellyn-ryland.co.uk/downloads/duralac.pdf If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Many thanks - I wasn't sure if I had to let it "go tacky" before assembly - now I know I don't
![]() Matt p.s. Now I've mixed the tube contents it's MUCH gooier ![]() Wish I'd used it for the security grills ![]() But shout it at them in German because life is also terrifying and confusing... |
