![]() | Home > Maintenance & Modifications > Battery Fuse |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
should have bought odysseys
but now you have the optima's get a seperate mega fuse holder |
| parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366
I've never had any probs with optimas so no need to change to any other.
Can anyone recommend a supplier for a new 500 amp fuse holder. 98 V8 Disco |
AES or VWP would be a good start, or maybe try RS components
| bolampau Member Since: 06 Jan 2012 Location: Lincolnshire Posts: 100
| mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645
Do you realise using 500A fuses you will need to use 70mm2 cable?
We do a twin pack using 300A fuses (35mm2 min) http://www.mobilecentre.co.uk/2-x-bluesea-...p-709.html So this is two fuses holders & three fuses. If you just want a single Most of the people linked to do not go above 250A |
Thank's all
The cables are ok, it's just the metal connector on top of the fuse that isn't long enough to reach the terminal on an optima battery. Maybe i can just weld on a longer bar rather than replace everything. Is the battery fuse on the puma different to a td5 ? 130 crew cab 98 V8 Disco |
