Home > My Defender > Tom Shepperd 300tdi Hardtop
Page 2 of 3 <123>
jst
i liked this truck from the first time i saw it in his book, loved the dash then which was simple and fwd thinking. good to see its still around.
So how many miles on it now? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #128311 2nd Mar 2012 10:34pm
farmer giles
Hi James,
milage is upto 132k but i had to put a Turner recon engine in 4k miles ago after a "sustained" run down to Winchester.
i will ask the IT bods at work how to use the scanner and see if i can get the LRO article up.
Post #128813 5th Mar 2012 9:19am
farmer giles
the external roof scoop is made out of mdf; but a friend has taken a mold and made several copies in fibreglass; when i put a version on my puma i will get a copy out of aluminium.
The grille on the underside of the vent is a grille from the bonnet of a RR classic (approx 250mmx100mm).
The internal mini vent controller come with tubular ducts that penetrate the roof and then sealed with mastic so i have not had any water penetrate the air vent. The external cover is bolted (x4) to the roof with captive bolts on the cover and a very thin compression gasget to the perimeter.
the rear tub of the vehicle has got 3 recessed lashdown points on the leading edges of the wheel arches. It also has a camping strip light rather than the small interior light in the headlining. The rear door has a dropdown tray and the door can be wedged open with a extending ali pole that is attached to the door head and a bracket fixed externally above the roof gutter. Tom also gave me a triangular canvas awning that threads into a slotted channel above the rear roof gutter out to the door so you can eat at the rear of the vehicle in the shade (or dry in the UK).
The vehicle came with all terrains on rostyles from memory but Tom also gave me a set of five sand tyres (i think they were the same as the standard military pattern?); and these were sold to Matt Savage.
Post #128819 5th Mar 2012 9:52am
RRUK
I remember this well and still have all my LRO's going back to 1992 when I first wanted to get a Series 3 (I was a young bloke then!)
Here's the scanned article for you all, looks a lot nicer when new! Very Happy
 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #128821 5th Mar 2012 10:25am
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
What a strangely-written article.
Anyway, the last line is amusing: "the authorised version will be welcome and timely". It only took until 2007 Rolling with laughter
Post #128823 5th Mar 2012 10:49am
farmer giles
cheers rruk,
i accept that it did look better when new but i tend to use my vehicles; if only i hadn't met the right girl, settled down, got married and started a family i could of kept it looking like new Wink
this is not ment to sound grumpy, merely resentful that i haven't got the amount of free time compared to when i was single Evil or Very Mad
Post #128833 5th Mar 2012 12:09pm
I always liked those tie-down points on the rear edge of the seat boxes - so simple and effective!
As far as i know they were custom-made and never available commercially, but if anyone knows differently please do tell! Any aftermarket parts makers want to start making them? I'd by a set!
Post #128845 5th Mar 2012 1:24pm
farmer giles
blackwolf - i believe Tom said the lash down fittings came from a boat chandlers. i'll let you do the search Sad
Post #128856 5th Mar 2012 2:27pm
ibexman
Who made all the individual parts for the dash???
Post #129723 8th Mar 2012 1:45pm
farmer giles
ibexman - the dash is a cut down and sprayed 300 tdi dash with an intrument binnicle from a disco; with the upper shelf and binnicle surround in painted mdf. it could all do with a rub down and repaint but i have been busy on doing up and extending our house since we were flooded in 2007
Post #129764 8th Mar 2012 3:30pm
Thanks for that, FG, I had always assumes that they had been specially made. If from a chandler there is a good chance I can find some since I live in Poole, the world epicentre of chandlers!
Post #129773 8th Mar 2012 4:42pm
Wow - not seen that vehicle before. It has some great ideas. It's a great shame the current range don't have the bulkhead vents Sad - one of my favourite features of the older vehicles.
Roof scoop would not look out of place on a rally/raid vehicle but again like the thinking behind it.
Did anyone ever track down those flush fitting tie-down bars?
Post #181238 2nd Nov 2012 10:35am
uninformed
1998 Defender 110 Other PU Alpine White
thanks for the lonk Farmer giles,
I still cant believe that with all Toms practicality, he would allow MDF to be used in/on his LR. No way in hell it will go near mine. I would still iike some close up pics of the roof vent if possible.
cheers
Serg
Post #234026 9th May 2013 10:41am
farmer giles
hi serg,
i will take some photos of the roof vent this weekend and post them on this thread on monday.
just out of interest why don't you like mdf? - curiosity not critism question?
Post #234316 10th May 2013 9:25am
uninformed
well if it is the same stuff as in Australia, it is a fine particle borad. That is timber particles. It is often used in kicthen and cabinet making. Many upper class homes of the early 90's here on the east coast used it for skirting boards (base board trim) Becasue the developers could run custom profiles easy and it painted well. After a few years if doesnt hold up well at all indoors. It is very easlily affected by moisture. Im a carpenter and could easliy make the roof vent out of it, but id cut off my right hand beford doing so. I have seen older small trucks (Isuzu, dyna, Mitsubishi etc) with molded plastic roof top vents that are at the front edge of windscreen, I would have thought this be the easy option.....
Post #234340 10th May 2013 11:26am
Page 2 of 3 <123>
