Home > Technical > Rain is getting in.
gilmore
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
Rain is getting in.
It rained all day today and I went out to check out whether the weather was getting into my (newly purchased) 50th. Big Cry Big Cry Big Cry The passenger footwell was wet, half of passenger seat cover was damp. Water was dripping from where the roof-lining meets the inner hard black rubber roll attached to the door aperture, about 2 inches from the leading end of the door. It wasn't coming in through door via the soft rubber seal on the doorframe - it was definitely coming in where the roof-lining meets the top of the door. I stuck the pointed end of a zip-tie in to "wick" the water away into a small bucket and collect about a cup full. I moved the car and got a small gush from the same place as the water shifted up in the roof. Some came down the driver's side from the corresponding point. It's got a sunroof. Is that the smoking gun? Cant feel any water/dampness in the rooflinign around it though.
Can anyone give me advice on next steps?
Thanks in advance.
cheers
rob
_____ All opinions expressed in this posting are my own and are not necessarily those of someone who knows what they are talking about.
Post #128691 4th Mar 2012 7:40pm
Yeh sell it
Ill find you a buyer
hold on found one Whistle
Post #128695 4th Mar 2012 8:02pm
Zagato
Laughing
The sunroofs are not sealed from new so that is your first point of call then check the roof seam and carry on from their working through the Defender Water Ingress guide - Google it Thumbs Up
Post #128698 4th Mar 2012 8:06pm
Shhhhh Whistle its a bad one really Whistle
Post #128699 4th Mar 2012 8:08pm
Zagato
Yeah the engines the only salvageable bit on it Wink
Post #128712 4th Mar 2012 8:31pm
ericvv
Post #128713 4th Mar 2012 8:36pm
gilmore
I should have known better than to expect sympathy. Big Cry All opinions expressed in this posting are my own and are not necessarily those of someone who knows what they are talking about.
Post #128720 4th Mar 2012 9:10pm
rossy
Stop being so horrid boys !
Gilmore I am as wet behind the ears as any newcomer to this vehicle can be. Mine is 6 months old. It leaks from the windscreen rubber. It leaks from the foam strip at the front. It leaks from the offside strip at the back and it leaks from a gap in the floor under the rear seat base where it wasn't alligned properly in the factory. I have to park it facing slightly nose down leaning to the left where possible and the leaks kind of stop then !
I know exactly how to fix it but need a couple of dry days in succession and that has not occurred here since I bought it ! I booked it into the dealer 60 miles away but chickened out because I didn't want them mashing up my smooth clunk free gearbox and transmission and I couldn't bear to be without it for a few days for a job that I'm sure I can do better myself.
There's a water ingress manual on this forum somewhere. I think Zag posted it. Its jolly useful but if you have a good look with a torch you can find water ingress points pretty easily.
I am amazed that any of them don't leak to be honest when you see how they are designed and assembled ! Laughing
Post #128738 4th Mar 2012 10:13pm
VeeTee
Netherlands
http://www.zee-rover.nl/downloads/water-ingress-manual.pdf Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #128744 4th Mar 2012 10:24pm
Rob sell her to me with that long haired Weimie she will only appreciate dry warm motors Whistle
Post #128747 4th Mar 2012 10:25pm
Rob, once you have downloaded the ingress manual, you'll need some dumdum filler, if you find some (anywhere - buy it, keep it and don't sell it to anyone) they've stopped making it ...
whilst working on your leaks (plural - yes it's a land rover) don't be afraid of taking the headlining out, it's quite robust)
took me 18 months to find the leak, i was in "head-lining-removal-denial" for 17 months Rolling with laughter
Post #128757 4th Mar 2012 10:40pm
ZeDefender
...wish I'd been that clever Rolling Eyes
Try putting duck tape (waterproof Thumbs Up) around the possible areas so you can find out where the leak/s are coming from - worked for me (top of windscreen rubber taking in water off the roof). Tell someone you love them today because life is short.
Post #128758 4th Mar 2012 10:41pm
gilmore
It doesn't have a section for sunroofs
Big Cry
rob All opinions expressed in this posting are my own and are not necessarily those of someone who knows what they are talking about.
Post #128764 4th Mar 2012 10:48pm
gilmore
You're a cruel man, Ken. Whistle
regs
Post #128765 4th Mar 2012 10:49pm
Gareth
Hey Rob, I'm in the same situation with my TD5 90. It leaks in exactly the same point on both sides. I also have a leak at the back somewhere, as this morning the carpets in the back were wet.
I am not worrying about it just yet, its too cold and damp to fix anything. When it get warmer, I am going to strip out the head liner, rear seats, and side trims to pin point the leak areas.
Betsy is 47 years old, and has a rag top, and does not leak at all, so there's progress for ya Laughing 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #128770 4th Mar 2012 11:02pm
