Home > Technical > How to remove Defender 90 TD5 ABS modulator
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Hi, my first post...I have a TD5 Defender 90, Special Vehicles built with roll-cage and some other stuff. It has ABS/TC
I have had it for 10 years, nearly since new, but over the last year the 3 Amigos have come on. I get them reset, but the garage tells me the error codes relate to the shuttle valve.
I've found a link to a possible fix (http://www.landroverclubvi.com/abs-mod.html) or have found a compay that can do a unit swap for approx �200.
My problem is how to get the modulator out of the car. Its in a very tight space between the brake servo and the wing/bulkhead. Is there any access holes to get to the rear nuts holding the unit in, and also the brake pipes that go into the modulator..?
If anyone has removed the unit, I'd be very glad to know how you did it!
Many thanks
Simon
Post #128385 3rd Mar 2012 2:02pm
T1G UP
remove the wing..easy then
Post #128405 3rd Mar 2012 3:20pm
couplands
Yeah, that seems to be the only way, but my roll-cage goes through the wing, so I'd need to take off the roll-cage too..!
This is getting a massive job.... Shocked
cheers
simon
Post #128407 3rd Mar 2012 3:31pm
T1G UP
Post #128408 3rd Mar 2012 3:35pm
I did mine a couple of weeks ago.
Masking tape the top and edge of the wing and it DOES come out. With patience and force Thumbs Up
Post #128413 3rd Mar 2012 3:56pm
couplands
GREENI,
What did you use to get to the two nuts on the rear of the modulator that hold it to the bracket..?
Did you remove anything else to get to them..
Glad to hear you got it out though, it gives me some hope..!
cheers
Simon
ps Just noticed in the workshop manual, it shows the modulator in the reverse position than mine - i.e. the inlet brake pipes and the 2 nuts securing the modulator to the bracket are at the front, not the rear as in mine. The electrical sockets are shown at the rear, but mine are at the front. Which way is yours..?[/img]
Post #128415 3rd Mar 2012 4:12pm
I think I used an adjustable head ratchet, and a ratchet spanner, undoing it all was not really a problem.
The rearward brake pipes were tough to undo, an extensive Snap-On tool collection really helps.
The hardest thing was getting it out of the hole
Ooh yeah, removing the bonnet helps.
Post #128441 3rd Mar 2012 7:02pm
couplands
GREENI - PM sent...
cheers
Simon
Post #128448 3rd Mar 2012 7:34pm
Rec'd and replied.
Answering a question, my absm is the same way as yours, plugs facing forward.
Post #128504 3rd Mar 2012 10:13pm
couplands
Greeni,
Just to let you know I finally managed to swap my ABS unit. A real pig to get out, but loosening the peddle box, lots of masking tape on the wing and some very fine ratchet spanners I got it out.
I got a replacement from the guy you told me about, so thanks for that tip. He is only a couple of miles from me, never knew he was there... Embarassed
Thanks again for your help, I'd never have done it without your help... Thumbs Up
cheers
simon
Post #149715 11th Jun 2012 12:06pm
kzycnn
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Simon, Greeni
Any chance of pointing me to the same place? My ABS modulator is coming out this week for testing at ECUTesting.com. Brake issues I've been having (link on the TD5 section) are still pointing at the modulator and I'm trying my best to avoid a huge replacement bill.
Cheers.
Tony
Post #263085 2nd Sep 2013 12:21pm
couplands
PM sent.
Glad to report the replacement ABS unit is still going strong (oops, kiss of death..!)
Have ECUtesting told you they cant fix it..?
Simon
Post #263089 2nd Sep 2013 12:39pm
kzycnn
Not yet, no. Have spoken to them with the symptoms and they say it sounds like the modulator is at fault. Next thing is to get it removed and sent to them - hopefully today or tomorrow.
Just waiting for them to say sorry, can't repair Sad
Thanks for the info - pm replied
Tony
Post #263101 2nd Sep 2013 1:06pm
Thor
United Kingdom 2002 Defender 110 Td5 CSW Bonatti Grey
I've done exactly the same, but ECU couldn't fix mine. After about 5-6 weeks of hunting for a second hand unit and being let down a couple of times by people selling units with the same fault I already have I've forked out the �1200 for a new one. Massively painful shelling it out but I want my truck back on the road as the mot has passed Sad
Good luck with yours!!!! Strong people are harder to kill and generally more useful!
Post #263168 2nd Sep 2013 6:08pm
kzycnn
I've got my fingers crossed but am already resigned to the big bill Crying or Very sad
If mine can't be fixed I'll no doubt go straight for a new one - really need the truck on the road and want the assurance it'll last a bit....
Tony
Post #263377 3rd Sep 2013 1:10pm
