Home > Td5 > Best oil for high mileage manual gearbox (r380)
amondeggs
United Kingdom 1999 Defender 90 Td5 HT Woodcote Green
Hi I want to change the gearbox Oil as I don't know last time it was done. I'm aware that this is usually done every 2 years.
I have a 1999 td5 manual. It is on its original gearbox and has done 192000 miles.
I have read that the difflock evolution oils are very good but pricy. I'm thinking of buying The evolution 2 for the gearbox and the evo 1 for the diffs.
My questions are
are they worth the money Question
Are they the best for my high mileage gearbox Question
Are there any better alternatives Question
Value your advice, thanks in advance Thumbs Up
Post #128086 1st Mar 2012 9:52pm
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
Alternatives are discussed here:
http://www.defender2.net/forum/topic7888.html
No idea if the stated info is correct though.
Thumbs Up
Post #128088 1st Mar 2012 9:54pm
wslr
I'd stick with the Havoline/Texaco MTF94 as stated by Land Rover.
Post #128099 1st Mar 2012 10:07pm
landy andy
Difflock stuff is great Bow down Bow down
Don't bother putting it in your diff's tho, not worth it.
Andy
Post #128105 1st Mar 2012 10:35pm
stevie d
United Kingdom 2003 Defender 90 Td5 SW Alpine White
Difflock supply fully synthetic gear oils at an inflated price.
You require:
MTF 75w80 GL4 for the gearbox
75w90 gear oil for the diffs/ transfer box GL5
Morris oils make Lodexol oil suitable for the gearbox (R380 specific)/ also Fuchs sintofluid is available as an alternative (from memory its GL5)
Fully synthetic gear oil 75w90 is readily available any make ok.
I would use fully synthetic oil for gearbox/ transfer box.
Can use semi syn for diffs and change annually.
Steve Thumbs Up Defender 90 TD5 Station Wagon
Discovery 3 HSE
BMW 330i Coupe
Post #128114 1st Mar 2012 10:58pm
ZeDefender
Motul Gear 300 (fully synthetic) has resurrected two of my old gearboxes - one in a 1974 VW Beetle and the other in a 2003 Audi with synchro problems. It's a bit pricey but I've been seriously impressed.
In retrospect, don't use additives unless as a last resort!
Matt Tell someone you love them today because life is short.
Post #128119 1st Mar 2012 11:12pm
noworries4x4
MTF is actually cheapest from your Land Rover dealer in 1ltr bottles, i just had a big search for the stuff for my Range Rover and its the genuine stuff. £6.30ltr If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #128120 1st Mar 2012 11:14pm
amondeggs
Ok thanks all, not sure what to go for but the job will get done ASAP
Cheers again Thumbs Up
Post #128129 1st Mar 2012 11:52pm
wslr
For the general record, in the last 2 years we had 2 R380's which didn't like the Morris Lodexol, despite the specs about being R380 friendly. One was in a P38, the other a Discovery2. Morris technical gave us the blurb about it being developed with LR in the Sahara. Rolling Eyes
Just use the MTF94, or spend out on something else mentioned here already.
Post #128133 2nd Mar 2012 12:21am
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
I had the same thing on my TD5 defender. Now running genuine oil and everything is ok again. I have changed my gearbox oil every 12k from new though, im sure it has helped a lot.
Pete
Post #128205 2nd Mar 2012 12:14pm
amondeggs
Still doing some more research, I like the thought of a fully synthetic oil but don't like the price of the diff lock evo stuff.
Spotted this
from: Liqui Moly. Fully synthetic gear oil (GL 5) SAE 75 W 90. £6.90 per litre
Looks ok to me Question anybody used it before Question any reason why it would not be suitable Question
Price looks very good to me for fully synthetic gear oil Thumbs Up
Post #128675 4th Mar 2012 6:25pm
Martin
Site Admin
Equivalents to Difflock oils: http://www.defender2.net/forum/topic7888.html?highlight=fuchs  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #128678 4th Mar 2012 6:32pm
in my 300tdi, the 4th gear was almost impossible to select when cold, as soon as it had warmed up it was fine. I spoke to Dave Ashcroft and he suggested the evo oil, works a treat. not tried evo in the diffs but Im going to when the time comes. Thumbs Up
Post #128685 4th Mar 2012 7:23pm
