![]() | Home > Puma (Tdci) > Metallic Rattle and other sounds |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2497 ![]() ![]() ![]() |
4 the second one I would look into the pressure sensor/valve on the common rail system. Puma 110" SW
shaun.mobile Member Since: 12 Dec 2011 Location: England Posts: 156 ![]() ![]() ![]() |
thsnks MK
is that something i can do myself or is it a dealer job? |
If that is the case it defenetly a non DIY work. As for the other noise, search here under rattle+turbo or heat shield. Puma 110" SW
cheers MK, that's one for the morning.
18stone Member Since: 16 Dec 2010 Location: Mid Essex Posts: 137 ![]() ![]() ![]() |
My fix for the heatshield rattle was to insert 3 small stainelss nuts between the shield and the rail it attaches to to lift the whole shield away from the manifold. Re-use the original bolts and you're done. Just make sure the mechanic that does your service doesn't take it upon himself to remove them thinking he's helping
