![]() | Home > Puma (Tdci) > tapping puma engine |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 ![]() ![]() |
Put some fuel conditioner in the tank to quieten it down.
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
Mine is the same at times ..... no pattern to it, some days it 'taps' more then others ... i blame fuel quality myself, dunno if im right though
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 610 ![]() ![]() |
Just need to alter the advance of the pilot injection a little between 1000 - 1500rpm at light to medium engine loads.
I could also ease the fuel pressure set points around these areas too. ![]() |
boxer Member Since: 12 Jun 2011 Location: north yorkshire Posts: 48 ![]() ![]() ![]() |
Think you could be right about fuel quality i started with bp fuel then jet and now morrison's filled up 2 days agone think its worse with morrison's fuel.I have read the posts regards adding 2 stroke oil etc but i am suprised how temperamental the engine seam's.
Fuel quality and cetane value matter, when it comes to keeping your engine quiet, and clean. 2 stroke works brilliantly!
Thanks for the info guys might start adding 2 stroke oil what mix is best and what make ?
bolampau Member Since: 06 Jan 2012 Location: Lincolnshire Posts: 100 ![]() ![]() ![]() |
as per recommendation from this forum I use:- http://www.opieoils.co.uk/p-928-motul-100-...gines.aspx Cheers, Paul |
I currently use Carlube 2 stroke, the red stuff. You don't need much, as a small bottle should last quite a few tank fulls, depending on the size of your tank of course. I put half a 250ml bottle in my TDV8 at a filling station earlier today, and got asked what I was doing by the bloke there. |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813 ![]() ![]() |
If you are in Tesco pick up some of their 2 stroke motor cycle oil oil. It is mineral based to FB standard which is good enough for the 2.4 Puma. Use 250 ml or 1/4 litre per tank. If you have a 2.2 Puma use FC spec 2 stroke owing to the DPF. fitted. Have been using 2 stroke at every fill up. Does not increase mpg appreciably but keeps everything smooth and quiet. Good for your emissions too. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
cheers paul have you noticed a difference using the oil
Yep, seems quieter and I add it at the rate of 250 to 300ml per tank. I buy Sainsbury's diesel as it's cheaper and the 2SO makes a difference. |
I will start adding tomorrow and report back cheers guys
AlpsLandy Member Since: 11 Jan 2012 Location: Alps Posts: 116 ![]() ![]() |
I have the same tapping with 1000 miles on the clock. Only bought fuel from Esso station but it is located at a supermarket... Most of my diesel driving neighbors use 'additives' but I thought no need if it's proper branded (additives included etc) fuel, maybe it isn't... Will try the 2SO trick - top tip, cheers. 2011 Defender 90 SW
2006 Discovery 3 HSE |
affiliate13 Member Since: 29 Jan 2012 Location: Belfast Posts: 82 ![]() ![]() |
Would this be suitable for 2.2 Pumas?
http://www.carlube.co.uk/index.cfm?product=78 I was reading in another thread here that it should be mineral based JASO-FC? |
