![]() | Home > Technical > Engine noise problem |
P0299 Turbo/supercharger underboost
quite "normal" in most of the Defenders Puma Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8360 ![]() ![]() ![]() |
Hi Bruce,
mines only done it on one particular trip and that was towing and coming to a rest to then pull away again. have fitted a SG now as i am interested to see Water temp as and when it does it again. i dont think its a manifold issue either for reasons as given. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518 ![]() ![]() |
Hi James,
I think we should close my thread and refer to this one..... ![]() What is a SG? Also if you do find the problem if there is one, please post it here and I will do the same. I have subscribed. I will again be doing a longesh highway trip this weekend but will not be towing. Will see if it does it again. |
I just had another thought......I was towing in 40 deg C plus temperatures, I would assume you to be in European winter temperatures, so it can not be heat related?
Just guessing again...... |
i was towing in Nov UK weather so cold ambient.
SG= scan gauge. will use this thread. have a tow trip, same load, this weekend, will see if it happens again. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
well its in for its 2nd service currently and i also asked them to look at this issue as iuts got slowly worse
and
was right, depsite the checks too. loose stud on exhaust manifold and failed gasket. i asked the guys if this was a common issue, response 'well we dont see it on every defender.............' ![]() James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 ![]() ![]() |
Mine did it, Taunton replaced the gasket under warranty and then 2 days later it started doing it again.
Hasn't been such an issue since the de-cat though. |
that doesnt sound good. do you know what caused it to fail either time? did you get it fixed the second time? Cheers
do Pumas has O2 sensors in the exh?
found this: First, yes the vehicle will experience a power loss, but as I said it may or may not be noticeable at first. What will be noticeable is the increased fuel consumption. This is due to the fact the O2 Sensors are detecting Oxygen in the exhaust gases. This indicates that there is unburned fuel in the exhaust and will send a signal to the ECM to lean the air/fuel mixture out. and was wondering if that accounted for the extra fuel the truck seems to be using.[/i] Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
theres not one in the cat section and i can't remember seeing one the other day. same pipe as a td5.
Only for Petrol engines, not diesel.
Since fitting my inter-cooler mine has not made the noise. Strange? |
