Home > Maintenance & Modifications > Safe T Pedal or Clutch Claw
taffyscouser
Any views on these? Need to add some mechanical security to the Puma and both look like they do the same job.
Taff
Post #126852 26th Feb 2012 1:48pm
ericvv
Post #126858 26th Feb 2012 2:02pm
WarPig
Adrenalin 4x4 pedal lock, got one on my 300tdi but they also do one for the puma.
Post #126861 26th Feb 2012 3:17pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
Got a clutch claw on the 90 and had it for about 6 or so years. The door has been forced twice but luckerly not had it taken yet.
Post #126862 26th Feb 2012 3:23pm
Zagato
Adrenalin4x4 pedal lock made of tougher stainless steel, can't drill out lock (well you can but it takes two hours Shocked It is designed to just spin....don't lose the keys Wink ), encloses all the pedals so cannot be driven away (you can drive a car without a clutch and brake of course!) or pedals chopped off leaving stumps to drive on bla bla Thumbs Up
This is pretty impregnable but bulky so I use it occasionally if it is parked up for any decent length of time. When I leave the car for short periods in a relatively safe place I use a steering lock as it's quick to put on and off Thumbs Up
Steering locks = ease of use but not very secure.
Pedal locks = bulky and longer to fit but would take someone hours or alot of noise and time trying to angle grind it off.
A convenient and very effective way to prevent theft is to disable the engine manually or electronically with the flick of a hidden switch! Used to have hidden flick cut off switch on the fuel pump of my Jag, ideal :wink:
Post #126876 26th Feb 2012 4:32pm
taffyscouser
Really like the look of the Adrenalin and Safe T Pedal. Will look to get one of these asap.
Post #127506 28th Feb 2012 7:46pm
RRUK
I bought the clutch claw on the basis that the bigger models need somwhere to go in the car when you are driving it, and a large loose bit of heavy metal in an emergency stop needs strapping down, otherwise it's a killing machine.
If you've ever been in a crash at speed you too will understand what I mean. Even a cassette tape can inflict injury (back in the day of cassette tapes) 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #127514 28th Feb 2012 8:01pm
The Boy
What about 8tracks? Rolling with laughter
Post #127519 28th Feb 2012 8:09pm
taffyscouser
Adrenalin site not working? No details re the pedal lock. Going for Safe T Pedal. Liked the look of Adrenalin one but cannot get site to show or list the product.
Post #127527 28th Feb 2012 8:39pm
James at adrenalin is a complete nightmare to contact and get any service.. there's a market out there for his products .. someone will pick those products up and make a killing Thumbs Up
alternatives.. ardcase, clutch claw, diskloc and mudstuff do a hydralic clutch lock ... all worth a punt
some alarms, immobilisers and trackers have bump sensors and the sophisticated ones have very sensitive movement sensors that will detect lifting and jacking. one day someone will come up with a propshaft lock
there's lots of kit out there, just get some on your truck Thumbs Up
Post #127565 28th Feb 2012 10:53pm
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
I had the same problem, James replied to one e-mail and then stopped so I got a Safe T Pedal
Post #127568 28th Feb 2012 10:59pm
EWS
United Kingdom 2006 Defender 90 Td5 HT Alveston Red
Thanks to all that have responded to my post. Did not think it would get a bit heated , or involve The Kennel Club . I agree if they want it bad enough they will take it, no matter what you do, even to using a Hiab crane , smash the side windows , chain through and lift it aboard , as they did with a friends Fourtrak, and no one made a report to the BiB., they told the only person inquiring it was sold for scrap !!!!. Well it was old !!!!, but perfect. Disturbingly my local Blunket plod has advised to let them take it , that’s what you pay insurance for!!!!!!!!!!!!!!!!!!!!!. Please do not start on “Plunkets”, we know most of them are a waste of time and , yes some do try to be good at there job.
Okay it seems the way to go is the “ Ardcase” or the “Safe T Pedal Lock” as the “Adrenalin” Pedal lock seems to unavailable . Though how you store these items when not in use seems to be a problem. And of course a 12 gauge , backed up with canine assistance taught not to take tit bits !!!
Many years ago a Game Keeper friend had one of these “Alarm Mines” fitted to his Series 2 Land Rover, press the clutch down and it triggered via a wire/pull pin, it fired in to the nether regions of the driver., it used a blank 12 gauge cartridge .
Link- Copy and paste . &feature=related
Post #127602 29th Feb 2012 2:39am
