Home > Technical > CBs and setting up
Page 1 of 3 123>
jst
CBs and setting up
Can anyone recommend a good CB antenna base for use on a LR that doesn't require any drilling or need a rack/ladder or similar to attach it to.
Gutter mounts dont seem to work that well in my experience which i presume is down to the lack of ground plane (earth)?
If you have mount that isint earthing through its base, ie due to being on Ali and paint, can you not just run a separate earth wire to the base or does it have to earth at the base for bext range/reception? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #127471 28th Feb 2012 6:02pm
Laurie
Re: CBs and setting up
Mag-mounts work fine without earthing, so it's obviously not essential.
Post #127473 28th Feb 2012 6:18pm
jst
mag mount to where? is the roof steel on them?
just seen thunder pole do an additional earth lead which would suggest you can run a separate earth for them i guess. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #127476 28th Feb 2012 6:21pm
pjw4233
United Kingdom 2011 Defender 90 Puma 2.4 HT Stornoway Grey
I use a Artificial Ground Plane attached to my roof rack The unit simulates a connection to ground, so you do not have to worry about your metal to metal earthing. This cured the SWR problems I had which was down to poor earthing and is also a good way of helping to reduce interference as it allows the aerial to be completely isolated from the vehicle.
Post #127482 28th Feb 2012 6:33pm
Laurie
I was merely using Mag-mounts as an example of an earthless aerial, not suggesting you try to use one.
Post #127486 28th Feb 2012 6:44pm
jst
cheers guys,
Laurie sorry i mis-interpreted it that you ran one on a defender.
PJW - do you have a link? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #127487 28th Feb 2012 6:48pm
pjw4233
Post #127494 28th Feb 2012 7:06pm
BigMike
here
http://www.jeepkj.com/forum/f293/how-insta...ing-28789/
On a defender you're pretty much stuffed apart from the above if you dont want to rack/ladder/gutter mount or dont want to drill. The link isn't a bad solution actually.
I had this on my last 90. Yes you do have to drill but it's neat and unobtrusive when the aerial is removed. Easy to fit too.
http://www.land-rover-blog.co.uk/how-to-in...-defender/
Post #127495 28th Feb 2012 7:09pm
Mountain_man
Wales
Not sure if it is possible on the Puma but IIRC it has a very similar rear wheel mount to the Discovery now. On myh old Disco I used some flat bar and mounted it to the same studs that hold the wheel carrier to the doorat the place where the top of the bar clears the top of the spare wheel I put a 90 degree return on the flat bar and mounted the aerial to that. hmm You will need to drill a hole into the door though I remember so unless there is a blanked grommet already then scrub that one!
Post #127501 28th Feb 2012 7:31pm
JWL
Years ago I had an Ifor Williams top on a 110 and used to put a magnetic base flashing light on the top when escorting farm machinery. To make it stick I had glued another magnetic base on the underside of the Ifor so that the 2 magnets would be attracted to each other. No reason not to stick one above the headlining on the underside of the roof.
Post #127505 28th Feb 2012 7:42pm
Happyoldgit
In my experience gutter mounts work fine on a Defender hardtop, just make sure the grub screws bite through the sealant & paintwork into the steel gutter below. Steve.
http://forums.lr4x4.com
Post #127508 28th Feb 2012 7:47pm
BigRuss
Top tip
Make sure you have the CB setup for the right region that you in! Whistle Russell
2011MY 110 XS USW Black
Post #127510 28th Feb 2012 7:53pm
jst
dont really want to get into the paint on this one! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #127511 28th Feb 2012 7:57pm
jst
been there, done that before too! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #127512 28th Feb 2012 7:58pm
Laurie
No need. Earth the set inside the vehicle instead.
Post #127515 28th Feb 2012 8:02pm
Page 1 of 3 123>
