![]() | Home > Maintenance & Modifications > 2.4 Puma Replacement Pipe |
| nick272 Member Since: 15 Feb 2012 Location: Northern Ireland Posts: 12
Hi, I have a 2007 2.4 Puma Defender and was looking about fitting a mid silencer replacement pipe and/or a 'de cat' pipe. Its purely for improving the sound. I know the TD5s sound good with these but does anybody know if the puma does? would be a great help if u could link me to a video or a sound clip etc. I have looked about and cant find any so far though.
do u reckon yours will sound good then? i probably wouldnt fit a whole new kit. Only the mid silencer probably. Wouldnt mind seeing/hearing what yours is like after its fitted though!
| Denis Member Since: 28 Dec 2010 Location: prairie Posts: 58
No difference on mine before and after. De-cat + mid-silencer replacement. Sorry
| The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459
Well after they put it up on the lift I was horrified to see how much corrosion was on the exhaust! The centre box was very rusty and the steel 10mm hooks that are welded to the system along its route were a minimum 50% rusted through. So I am having the whole lot changed to stainless steel in April. I am having a centre box on it but that is smaller and sits higher up than the original but no tail box. They more or less do anything you want so you could if you wanted have just the straight through centre and a tail box. http://demandengineering.co.uk/
probably explains the lack of videos/sound clips...
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18031
What's the reason for the dummy cat? |
I think so. As far as I know for better sound you need to change/remove rear (small) silencer Cheers Puma 110 |
Thanks the Boy, will check them out. Denis, do u know if u have to get rid of all of the silencers to get a good sound, or is it just the rear one?
With all this stuff about cats might need to be left on in order to pass the mot I was a bit worried. I know some have said it will only apply to petrol engines but if it doesn't I will be up the creek. If it is defiantly only petrol then there will not be a problem and a simple pipe will suffice. |
Nick - just the rear one imo Puma 110
| pjw4233 Member Since: 30 Nov 2009 Location: Lake District & Cheshire Posts: 273
&list=UUVjoa15O9LXMp_kQe3C_ahg&index=35&feature=plcp |
Thanks Denis, I have seen those videos already haha, im not sure they show enough to convince me though. Wish i could find one of them going for a bit longer.
| Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507
Made a difference on mine, and it sounds ok [least i think so]
Short clip here http://www.facebook.com/photo.php?v=358156820872601 Guns and Landrovers .... anything else is irrelevant. |
Dave, i would have to add you as a friend first, u cant upload it to this easily? Thanks
