Home > Puma (Tdci) > Screaming Turbo when Hot
Page 2 of 4 <1234>
jst
http://www.defender2.net/forum/topic9410.html
is this the same problem? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #127230 27th Feb 2012 9:03pm
Naks
Re: Screaming Turbo when Hot
BruceT wrote:
Not sure how to discribe this, but after a long trip when my vehicle is hot there is a screaming noise when pulling away in first and 2nd gear.
Bruce, that sounds like a leaking exhaust manifold. Any indication of soot around that area? --
Post #127233 27th Feb 2012 9:07pm
jst
my thoughts were geared towards viscous as it doesn't always do it. the only times it did/does it on mine would be when i would expect the viscous to be locked up, ie post hard work and then heat soak prior to a pull away
if it was an exhaust manifold wouldn't it do it all the time? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #127262 27th Feb 2012 10:20pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Quality product placement with the inspection lamp there Brian!
Pete
Post #127283 27th Feb 2012 11:21pm
BruceT
South Africa
thanks all for the replies. Will keep an eye on this thread for updates.
Post #127315 28th Feb 2012 6:26am
Lorryman100
Pete
I didn't notice that till you pointed it out. I used it to illuminate the heat shield bolts, if it was the other way around It would light up me instead. Whistle
I've deleted the picture. Thumbs Up
Post #127462 28th Feb 2012 4:55pm
BruceT
South Africa
JST that sounds like its exactly the same problem as mine.
Post #127607 29th Feb 2012 6:54am
jst
what were your thoughts then leading to turbo over anything else? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #127701 29th Feb 2012 3:29pm
BruceT
South Africa
Reason I thought turbo is because of the sound and it only did it under load or under boost and at no other time. When I released the accelerator and accelerated again it stopped. I read the comment about the clutch but it definitely does not come from that area, unless my ears are playing games on me and I doubt its the fan as I have heard the fan come on in heavy traffic.
Now I am totally guessing with this, and trying to think logically, but I believe that these motors run a variable vein turbo.....I am just wondering if perhaps the veins get "stuck" in one position after a long trip under constant load causing the sound and then release themselves when cooler or asked to work at / stressed at different levels. (hope that makes sense)
Post #127703 29th Feb 2012 3:39pm
Lorryman100
Bruce you can check the control bar between the modulator output arm and the VV control arm. Both ends of the bar should move and it will feel quite loose, there should also be some side to side movement of the bar and both ends should have grease on them. Though I can't see this causing the sound you are on about Confused
Brian.
Post #127819 29th Feb 2012 9:30pm
BruceT
South Africa
thank you Brian will check.
Post #127885 1st Mar 2012 7:29am
pascal
Cyprus 2013 Defender 110 Puma 2.2 XS DCPU Indus Silver
BruceT wrote:
Hi all,
Doesnt do it any other time. Only when I have done a few hundred kms of highway cruising.
It definately sounds like its related to the turbo.
Any ideas what it could be?
(its a MY11 Puma 110 with 37k kms on it)
Thank you
Finally what was the problem, did u fix it? I have exactly the same issue with my 2014 double cab.
Tnx
Post #322305 8th Apr 2014 7:16am
BruceT
South Africa
Yes eventually after being told many times that nothing was wrong, i insisted that Land Rover remove the exhaust from just below the turbo. When they did that they found that it had been leaking at the joint. Never had a problem again. "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
23MY Defender 110 D300 HSE X-Dynamic
https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA
Post #322307 8th Apr 2014 7:20am
landy andy
Thanks all for the above comments. Think I have this problem with mine. Sounds between a scream, and a whoosh noise but only when hot and whilst accelerating hard, like pulling away.
Andy
Post #323222 12th Apr 2014 7:43am
landy andy
Is Brendan the man to supply the uprated gasket?
Andy
Post #323223 12th Apr 2014 7:56am
Page 2 of 4 <1234>
