Home > Maintenance & Modifications > windscreen washers
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
windscreen washers
anyone done a mod on the TD5 windscreen washers mine are as much use as a chocolate teapot and seem to move form time to time Evil or Very Mad .
i was thinking of fitting washers to the wiper arm?
Post #127065 27th Feb 2012 1:52pm
WarPig
Yep, done it to my 300tdi. Easy job to do.
I pulled out the dash top ashtray to expose the washer pipe connection with the washer nozzle. Undid the brass nut, pulled the pipe off, inserted a 'T' piece (available from aquatic shops and at BnQ in their hosepipe section).
Then using some similar pipe to existing, I fed a piece into the hole next to the wiper arm from the outside, and fished it through the dash and out of the ashtray hole, and connected to the 'T' piece. Repeated on the other wiper arm.
I tie clipped the pipe along each wiper arm and then connected it to a Peugeot spray arm - about £12 from Peugeot dealer, or cheaper from scrap yard.
The original washer nozzle remains, but unconnected. Though with a suitable '+' piece no doubt you could utilise that too?
Post #127237 27th Feb 2012 9:14pm
tolley
many thanks any photos
Post #127241 27th Feb 2012 9:24pm
markb110
Hi Tolley
Has an alterative you can move the existing washer to the left or right (LHD wiper holes) and and a second washer jet.See my picture.
Take the top of the dash off and use a T piece and extra pipe from Halfords to join it all together.
The advantage is two jets of water per side of the windscreen.
Any questions just ask
Good
Mark
Post #127243 27th Feb 2012 9:36pm
markb110 wrote:
Hi Tolley
Mark
great idea Mark - nice shine on the truck too ... have you been Zagged ?
Post #127249 27th Feb 2012 9:56pm
tolley
great Mark thanks
Post #127251 27th Feb 2012 9:58pm
markb110
Hi Steve
Not Zagged
Bucket of water with cleaning gunk / sponge / chammy LOL
Picture was taken last year.
Last time i cleaned it i got three buckets worth of mud of the underside - which has helped build up the vegetable patch ready for planting in the next two months - never one to waste the good stuff
Mark
Post #127266 27th Feb 2012 10:32pm
WarPig
I can take some for you, but Im away on a training course at the momemt, will try and take some at the end of the week.
I'll send you a PM with more details Thumbs Up
Post #127309 28th Feb 2012 12:44am
tolley
mark was it much of a job,is there enough pressure for the two to work ok off the one pump.?
Post #127402 28th Feb 2012 1:24pm
markb110
Hi Tolley
The job is not hard - just lots of screws
The pump is fine - i use the car fro green laning and club days and this set up is much better than the one squirt per side original.
Shopping list to start
1 x front washer jet - £3.00 approx from ebay (not rear as this is shorter)
T piece from Halfords
Washer pipe from Halfords - take the washer jet with you as there are two sizes
Good stubby philips screw driver if you dont already have one
Blanking grommet (to fill the original hole once you move the current washer jet) - check the size and search ebay for rubber blanking grommets - from memory Halfords did not have the right size.
Start by removing the two dash ends, then the instrument panel (once this is lose disconnect the multiplug and remove to give you more space)
Remove the top air vent covers, then the screws that are closest to the windscreen (hence stubby screwdriver) then the screws along the front edge. Use sandwich bags / jam jars to seperate the screws with a note to help you replace.
Once dash top off you will see the original set up. Cut the pipe where you can nearest the current washer then remove the holding nut and then pull the washer out from the front.
Remove the two (LHD) wiper blanking grommets and pierce a hole through the centre - push the nose of the jets through it and replace into the new position.
The fiddly bit is to get the lock nut onto the ends here - its a pain - just take you time and introduce you neighbours to some new words, it will make you feel better.
The nut only needs to be finger tight and allow the jet to move to where you want it to be once ready.
Cut two lengths of washer pipes (too long is better than two short) and push onto the ends of the washer jets - put the pipe ends in a mug of boiled water to soften them up and reduce the chance of snapping the end off the jet.
Once done decide where you want to the T piece to go, shorten the pipes join everthing up.
Do test that everthing works and there are no leaks (should not happen) and check that you have not knocked the under dash heating vent - ie put the fan on full blast and check the air pressure - this will save you having to take the dash apart again - wont say how i know Whistle
Once happy refit the dash, instrument panel, dash ends and keep safe any left over screws, they seem to multiply for some reason!
Once done then you can both adjust the washer units and then the jets to suit you.
One of the lads in the club had a similar sent up to Warpig and replaced the wiper arms with those from a Puegot as they have the washer pipes included which look nicer than the comp safari versions with the pipes zip tied to the arms
Anyway - hope this helps and good luck
Mark
Post #127496 28th Feb 2012 7:11pm
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
There's a good write up here on doing this mod. Thumbs Up Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #127575 28th Feb 2012 11:06pm
tolley
done it Smile
[/img]
Mr. Green all went well ,only pain in the bum was getting the nut off
the old washer.
Post #131332 14th Mar 2012 4:59pm
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
Tolley, when you fitted the new washers, did the nut on the back disappear into the bulkhead? On my 2004 TD5 the LHD wiper holes are a sort of rounded oval and the nut fits inside very nicely, but you can't get a socket in there to do them up!
In the end I ran out of time and put it all back together again! Dave
Green Goddess - 1998 Defender 110 300tdi
Post #131347 14th Mar 2012 7:23pm
tolley
i know what you mean mine went right in at first,just put a washer on the inside Thumbs Up .i could just about get a socket on with a angle piece on the end,had to take most of the dash out but it was only more screws the hard job was remembering which went where. Smile
Post #131362 14th Mar 2012 8:12pm
nosnibod
Now why didn't I think of that? Thumbs Up Dave
Post #131382 14th Mar 2012 9:01pm
