|  | Home > Puma (Tdci) > Screaming Turbo when Hot |
| RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363    | A leaking intercooler hose?? I had a hoseclip snap on my TD5 and i changed them all for a better make. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS.. | ||
|  27th Feb 2012 12:13pm |
| BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518    | No doesnt sound like that and only does it after long trips. Sitting in traffic and short trips - no sound. | ||
|  27th Feb 2012 12:15pm |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18058      | Could be the early stages of a split in the pipe from turbo to intercooler.  The pipe is softer when hot.
 Mine did something similar as it started to wear through on the steering column lower clamp bolt. | ||
|  27th Feb 2012 12:45pm |
| robharvey Member Since: 14 Dec 2009 Location: Durban Posts: 86      | Bruce,
 Not something to do with the viscous fan? I've had my turbo make an odd noise once. I was towing another Defender on a flatbed trailer at about 1600m above sea-level going up a steep incline, and had done about 400km already, so the turbo was working hard. There was a definite screeching sound from what I thought was the turbo for about 10 seconds, almost as though there was no oil in it. Haven't heard it again, though (and hoping I don't either). Asked for the turbo to be checked at the next service, clean bill of health (for what it's worth). | ||
|  27th Feb 2012 12:46pm |
| Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686  | Take off the turbo heat shield and check the turbo/manifold gasket for signs of soot. It seems to be a common occurrence on the Puma for the Turbo manifold to warp and allow the exhaust gases to vent out through the now defunct gasket. If this is the case then Nakatanenga (site sponsor) can supply you with an annealed copper gasket which moulds itself to the warp and reseals the join. If the Turbo manifold is OK then it is probably an intercooler pipe that is causing the scream. Check all joints and that none of the hoses are holed anywhere, there is a service bulletin ref a plastic stud on the inner face of the wheel arch line that over time holes the nearby intercooler pipe:
   Click image to enlarge I recently had a squeal on my Puma, but only when hot, which sounded like a slipping fan belt? After a bit of investigation it turned out to be a loose pipe clip on the turbo hose causing the pipe to make it's way off the turbo. After repositioning the pipe onto the Turbo, and doing up the pipe clip tightly, the squealing sound has now gone.   Click image to enlarge HTH Brian. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated   | ||
|  27th Feb 2012 12:54pm |
| BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518    | Thank you for the replies. The fan belt slip describes the sound more closely. Its definately not a loose or split boost pipe.
 What is confusing is that it only happens sometimes. I towed a heavy xplorer (caravan) down to Mosselbay in December. Did the trip in 14 or so hours in one go. No squeal, but when I did the return tripthere was the squeal for a short while until the vehicle seemed to cool down. It is almost due for a service now and is under warrenty so will get the stealer to check. Thanks again for the replies. | ||
|  27th Feb 2012 1:05pm |
| Landyash Member Since: 06 Feb 2011 Location: Nottinghamshire Posts: 287      | Sounds like  a leaking turbo to manifold gasket, it's a metal type gasket, had the same problem with mine , it sounded like a police siren.
 Cheers Ash. | ||
|  27th Feb 2012 1:57pm |
| BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518    | Ash did yours scream all the time or only when hot? | ||
|  27th Feb 2012 2:04pm |
| ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731      | Same question from me    Mine does it all the time from cold around 2000 rpm (another issue for the first service  ) Cheers, Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... | ||
|  27th Feb 2012 2:24pm |
| Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2114      | Same is mine some time ago.
 Turned to be a the manifold gasket. Were most audible over the 2000 RPM in all conditiosn (hot/cold) Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo"   Click image to enlarge | ||
|  27th Feb 2012 2:43pm |
| ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731      | Cheers Eduardo - just need to convince LR to use the Nakatanenga gasket under warranty   Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... | ||
|  27th Feb 2012 4:04pm |
| Landyash Member Since: 06 Feb 2011 Location: Nottinghamshire Posts: 287      | Hi BruceT mine did it hot all cold,me bčing a tight git fitted the standard one.
 If its only when hot some thing is expanding might be a cracked manifold   Good look  | ||
|  27th Feb 2012 4:30pm |
| Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686  | After reading the above posts I decided to go outside and remove the turbo heat shield and have a poke about looking for any soot deposits around the Turbo manifold/Exhaust manifold, I did not find any. If the turbo manifold is clean, then I would be double checking all the intercooler hoses again just to make sure that is not the cause.       Click image to enlarge   Click image to enlarge   Click image to enlarge   Click image to enlarge The black smudges you can see on the join are from my dirty fingers when I ran them over the joint as it appears the Turbo is not tightly secured? It is, as I could not get any movement on the nuts.   The cause of the squealing on my Puma was the pipe clip being loose and you can see the before and after pics below.   Click image to enlarge   Click image to enlarge HTH Brian. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated   Last edited by Lorryman100 on 28th Feb 2012 3:57pm. Edited 1 time in total | ||
|  27th Feb 2012 4:32pm |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8493      | i had these symptons too, there is a post here somewhere about it.
 all hoses are good, no soot marks found etc. in the end i put it down to the viscous fan. if i can find the thread i will link it in as it describes the symptons in more detail. Mine is yet to repeat it since the initial post i put up. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop | ||
|  27th Feb 2012 8:02pm |
| Posting Rules
