Home > Technical > Advice please - dismembering handbrake?
ZeDefender
Before I finally go to the dealers again with my bloody clattering noises, I've decided to do what everyone suggests Rolling Eyes and remove the handbrake shoes to rule them out as a problem Thumbs Up
Since I'll have to do it in the parkgarage at work, I don't want any nasty surprises...
AFAIK, I have to:
1) undo the 4 nuts on the drum (already bought a ring spanner for this),
2) slide the propshaft back (it should slide back easily?),
3) unhook the springs and remove shoes, pistons etc. (leaving the cable attached to something?)
4) put the drum/shaft back on.
I have this guide:
http://www.repairmylandrover.co.uk/defende...lue_Plugin
Is there anything more I need to know about taking it all apart, i.e. tricky bits, special tools or injury?
Any help/advice much appreciated Very Happy
Cheers,
Matt Tell someone you love them today because life is short.
Post #126472 24th Feb 2012 8:38pm
chiefstoker
England 2005 Defender 90 Td5 HT Zambezi Silver
Dont mean to be cheeky, but I did chuckle when you said you bought a ring spanner Laughing
Good luck dude Thumbs Up 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy
Post #126504 24th Feb 2012 9:41pm
ZeDefender
I guess I'm a bit slow on the uptake re. spanners Whistle but thanks for the encouragement Thumbs Up Tell someone you love them today because life is short.
Post #126546 24th Feb 2012 11:58pm
Bit of a safety moment:
Do the work on level ground
Chock your vehicle to stop it moving
BP
Post #126562 25th Feb 2012 7:35am
ZeDefender
BP
Er...good point Whistle Tell someone you love them today because life is short.
Post #126648 25th Feb 2012 4:51pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Normally i end up having to take the rear prop off at both ends as it doesnt slide back far enough to clear the studs in the drum, i do have a 90 though so you may be ok with the 110. Also what size spanner did you buy? unless its changed on the puma you need a 9/16 AF not a 14mm one, its a common mistake people make.
Pete.
Post #126654 25th Feb 2012 5:51pm
ZeDefender
Cheers. Yeah - I was worried about sliding the prop back - perhaps someone here knows if you can do it on a 110.
I bought a 9/16" spanner last Summer when I thought about doing it then - didn't have the balls until now Laughing
Do you have any trouble getting the shoes out/in? I'm trying to figure out what I can leave inside there whilst I'm driving around to test it... Tell someone you love them today because life is short.
Post #126655 25th Feb 2012 5:55pm
Blaserman
England 2011 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Is it clattering when its hot and you brake pulling up to stop?
If so get under it and back the handbrake off with a 17mm spanner only about 1/4 - 1/2 a turn problem solved. unfortunatly you will need to do this pretty much everytime it comes back from the dealers.
Post #126905 26th Feb 2012 6:21pm
ZeDefender
Yes, but the German dealers screwed it up so badly last time that the lever is vertical when I pull it Shocked
As they've "tried" to fix the clattering twice and I also have trouble changing from second to third gear (after my last visit Rolling Eyes ) I thought I'd try to rule out the possibility of gear/transfer box problems causing the noise.
However, I will again do as you suggest before I rip it's guts out - thanks for the reminder Thumbs Up
Post #126914 26th Feb 2012 6:48pm
ickle
The lever going near vertical will be adjustment on the cable, not necessarily the clearance between drum and shoe & yes you need to drop the prop off the rear axle first IIRC.
Keith
Post #126916 26th Feb 2012 6:59pm
ZeDefender
Cheers Thumbs Up
When I looked underneath, they've adjusted the cable almost completely out - I have no idea what they've done at the drum end Rolling Eyes
Stiil, going to a different dealer soon - maybe more luck there... Tell someone you love them today because life is short.
Post #126917 26th Feb 2012 7:08pm
Sticky
England 2016 Defender 130 Puma 2.4 HCPU Stornoway Grey
I had this problem from new and the dealers swapped a couple of drum's and swapped the cable, which improved things but occasionally the clattering would come back.
My solution in the end was to back the shoes off and put up with the brake handle coming up higher than is usual, although randomly it will brake on only three or four clicks. I worry that it has got hot and that at some point it is going to cool down and roll down a hill. I used a laser temperature gauge to look at how hot the drum was getting and that seemed to be linked, now the pads are backed right off I never get the clattering.
I always leave it in gear and think about which way the wheels are pointing.
The only guarantee is probably something like X-Eng XBrake http://www.x-eng.co.uk/X-BrakeDef.asp?MID=31 my local dealer service manager was so frustrated after the weekly visits that he recommended when the warranty ended to consider changing it.
Post #127213 27th Feb 2012 8:24pm
RFT
United Kingdom 2010 Defender 130 Puma 2.4 HCPU Zermatt Silver
Another little safety moment: (oil industry thing)
If you are doing this at work car park, you will appreciate the general iq of your work colleagues better than I but I can expect at least 2 risks:
1. Some one drives over your feet if they are hanging out of the side of the vehicle because they are stupid.
2. The sight of you under your vehicle over loads their brain and they promptly drive into your vehicle injuring you in the process.
spent most of my working life predicting what can go wrong when carrying out maintenance, if it can happen some Censored will let it happen. 130 Puma HCPU with an Artica 240LR Demountable Camper
Post #127222 27th Feb 2012 8:43pm
ZeDefender
I actually have one already and waiting in my garage! Incidentally, Simon at X-Eng is a brilliant chap Thumbs Up
Won't fit it until warranty expires (still 2 years) but didn't want to miss the chance to get one Laughing
I'll try playing with the adjuster again tomorrow, but bear in mind the handle is already at vertical before I back anything off Rolling Eyes
Thanks RFT - both scenarios are likely in my workplace Laughing Tell someone you love them today because life is short.
Post #127235 27th Feb 2012 9:09pm
Sticky
Don't forget you can adjust the pads away from the drum with the adjuster on the drum and wind the cable back separately.
Post #127299 28th Feb 2012 12:11am
