![]() | Home > Technical > headlight main beam fuse keeps blowing ** FIXED ! ** |
do you have any modifications to the wiring eg Aux. spot lights ?
if so, can you isolate these from the circuit and re-test ? do you have a picture of the grey coloured connector ? |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2066 ![]() ![]() |
Check for wire chaffing on the edge of the wing under the bonnet probably near the back left corner.
I posted about this on 1st dec 2009 under the subject: Headlamp wiring chaffed against wing edge Do a search in my posts. DAZ110 |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1297 ![]() ![]() ![]() |
thanks for the replies
nothing extra fitted and the wiring seems to be well away from anything that can cause chaffing. When I can remember how to post a pic I will but following the wires from the headlight they go into this little connector (just under the steering wheel area of the bulkhead right under the seal where the back of the bonnet shuts). We have had a monumental volume of rain here in the last few months and I'm convinced that has something to do with it. I wish I had a garage or carport. Our garden covers about an acre so I might have to budget for one in the future ! |
![]() Click image to enlarge many thanks Daz ![]() I was on the verge of trundling up to the dealer but then I searched for your post. I followed your advice and traced the wires. Sure enough they were routed so tight against a brake pipe that chaffing had worn through the insulation causing a short so a bit of insulation tape and a cable tie to pull them clear did the trick and I can dazzle again. I thought it might be beneficial to post a pic so everyone can check theirs simply because I can't be the only one with this problem. So if you look at the picture three of the wires to the left of the grey connector are from your drivers side headlights. You can see that they go reassuringly into a piece of trunking. Trouble is the trunking is only about 5" long after which they are just taped together and vulnerable to chaffing. If you follow their path you can see if they are rubbing against anything - if they are it won't be long before they pop a fuse and kill the lights ! |
I don't like to say 'told you so', but I did tell you so, if you get what I mean....!
![]() I knew as soon as you posted originally that you had the same fault as I had in the past. ![]() Anyway, glad you found the fault and fixed it. ![]() Cheers DAZ110 |
Thanks for the follow-up solution - ill be checking mine shortly
colinthill Member Since: 13 Jun 2019 Location: Surrey Posts: 3 ![]() ![]() ![]() |
hi new to the forum but found it searching for Defender main beam fuse blowing. Guess where I shall be looking this weekend to fix the problem. Is this why Landcover put the high beam on a separate fuse.
![]() Now I have found this forum its top my list for Defender stuff. Cheers Daz and rossy for the info and picture |
Crikey, this post started back in February 2012 !
Some design faults just reoccur, mine is an 02 plate 110
Cheers |
sorted, yep the wire was chaffing on the edge of the down fold of the wing. well protected now.
Thanks |
