Home > Maintenance & Modifications > Connect to trailer battery charging system
ralton
South Africa 2007 Defender 90 Puma 2.4 SW Zermatt Silver
Greetings from Africa!
Please advise:
I want to connect my trailer (which has an on-board battery and charging system) to my Defender 90 so that the deep cycle battery can charge while i drive around (with my elbow out the window).
Some say there's a "spare Hella" connection near the rear speakers? Can i somehow connect this to the brad harrison plug on the trailer?
Or do i need to run new wires from the battery? If so, what specs and what route through the vehicle?
Or should i rather get this done by a pro?
Cheers www.ralton.co.za
Post #126074 23rd Feb 2012 7:58am
VeeTee
Netherlands
Depends on which type of electrical plug you have connecting the trailer to the car, most connections have a permanent live 12V feed.
 Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #126075 23rd Feb 2012 8:14am
ralton
Hi
As per my post - there's a brad harrison plug on the trailer for the charging system.. www.ralton.co.za
Post #126115 23rd Feb 2012 1:39pm
Lorryman100
Is it a 2 or 3 pole with Earth plug? Is it already wired to the trailer battery and charger? If so just run the new 12v live direct from the battery to the plug connection on the Defender. In the UK the 12S socket supplies the fused live 12V supply to the trailer (caravans.) through a split charge relay, and this feed is taken directly from the vehicle battery.
HTH Brian.
Post #126117 23rd Feb 2012 1:51pm
